Results 1 to 16 of 16
    Mar 2003
    I have been joining avi's and converting to dvd no probs until now. I have this avi film in two parts however when I try and join them using Vdub the audio goes right out of synch in the second half even though avi part two is in synch is there anything I can do it is driving me crazy.
    Please help
    Many thanx
  2. is it a gradual loss or it a set amount of loss
  3. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Are you making a DVD? If so, then just make two mpegs and author them together onto one disk. There will be a slight pause between tracks.
    Mar 2003
    A set amount from the point of the join of the second avi.
    Mar 2003
    thanx ZippyP. I have already tried this but the pause is quite noticeable in the middle of a film.
    Any other ideas??
    Cheers
  6. Join the 2 video streams together, then load the 2 audio streams into Audacity and cut/splice the audio around the point of the transition so that the audio matches the video. Match the timestamp of the audio to the timestamp of the video at a notable part (i.e. a gunshot) Then mux the audio and video together.
    -Suntan
    Mar 2003
    I don't want to appear dumb or be a pain in the **** but I need more detail. If you have the time I would really appreciate a more indepth guide to using Audacity. I joined the avi's together using Vdub and then saved the audio as a wav file and then loaded this into Audacity but all I seem to be able to get is a squeeky noise. Am I on the right tracks or completely wrong??
    Any guidance would be greatly appreciated
    Cheers guys
  8. Are you sure you have a ligitimite .WAV file? (I haven't every really needed to deal with demuxing avi's as I always start with my DVDs so I am not overly familiar with vdubs demux capabilities) Open the WAV file in a regular player (like winamp, or zoomplayer) and make sure that it plays alright and it shows that it is acually a wav file and not a different format that just had its extension changed to .WAV. If it plays in a player then it should work without hassle in Audacity.
    Audacity's help index is HERE. I really don't use it all that much so I can't really give good help with it.
    Did you try Import RAW Data? It might work.
    -Suntan
  9. lynxer
    What kind of audio is contained in the original avi files. ac3, vbr, etc?
  10. You can encode each part to mpeg individually. After encoding join the 2 mpeg files with tmpgenc->Mpeg Tools->Cut Join.
    Mar 2003
    Laddydaddy
    AC3 audio - does this make a difference??
  12. Lynxer wrote;
    I believe so. First you need t download the AC3 ACM decompressor from the tools section and install it. Then load your first avi into VDub and choose audio>full processing mode. Then audio>compression_ac3 acm decompressor. Then file>save wav. You will now get an uncompressed wav file. With the original avi still loaded in Vdub choose audio>wav audio. and navigate to the wav file you just created and load it. Then choose audio>direct stream copy, video>direct stream copy, and finally file>save as avi. You will now have a new avi file which contains the wav file you created. Repeat the process for the other avi file. Load your 2 NEW avi files into VDub and see if the A/V is still out of sync.
    Mar 2003
    Laddydaddy - that worked FANTASTIC thanx very very much.
    However I now have another avi with an audio which is Fraunhofer IIS MPEG Layer-3 (whatever that means), and the same thing is happening. Can you work your magic again?? Pleeeeeease???
    Many thanx.
  14. That means you have mp3 audio compressed with Fraunhofer mp3 codec. Repeat the procedure above, skipping "audio>compression_ac3 acm decompressor" step. Well, good luck.
    Mar 2004
    DFW, TX
    Hi. I've also had trouble before with joining .avi's together and having out of sync audio after it's reached the part where the two .avi's were joined. Currently I have two files with .ac3 audio I'm trying to join. I tried Laddydaddy's method and downloaded and installed AC3 ACM decompressor. I load in my avi and set the audio to 'full processing mode' then I go to compression and set it to 'ac3 acm decompressor'. When I try to save it as a .wav file as soon as I hit the save button I get this error message, "Error initializing audio stream compression: The requested conversion is not possible." Can anybody help me and tell me what I might be doing wrong or what I can do to fix this? Any help would be appreciated.
    Mar 2003
    Hi again,
    I have followed the instructions given before and up until now they have worked great. However, i now have come across another problem. Again I have a two part avi but when i try to load them into Vdub i get a message saying audio samples differ. I decompress the audio and resave the avis. I can then join them in Vdub BUT when I replay the whole file it goes out of synch from the point of the join. Any ideas.
    Many thanx
