  1. I have been trying to capture with Power Producer. I can hear the audio fine while the capture is in progress, but replaying a captured clip produces no audio. Powerdvd played the capture with sound, but I had burned a DVD with power producer that had no audio, because I assumed I was ok since I heard it during the capture. ANy ideas? I tried reinstalling, etc. No luck so far. It would be great to verify that I will have audio before actually burning.
    no audio on your computer or standalone dvd player?
    what kind of audio is it? mp2, pcm or ac3?
  3. Hi,
    No sound on the PC through Power Producer. MPEG from capture plays ok in other apps. DVD burned from the MPEG2 fiile has no audio anywhere played. I believe the audio is PCM. I was thinking maybe it's a codec missing somewhere or something.
