I dont know why, but every time I try to covert an avi to MPEG1 to do a VCD the file starts converting but after 10 minutes the computers reboots!
This happens with different files.
I know there must be something wrong my my cpu cause none of files work!
I am a bit lost, can some help me please?
Thanks a lot,
diego.
Results 1 to 9 of 9
thanks for your answer Suntan!
I found something that can help.
While doing a movie just yet, I ve got this error:
TMPGEnc Error: "Illegal MPEG Audio Stream"
What is that?
I First open the movie with VirtualDub and save the audio file as a wav.
Then I open the TMPGEnc and select the movie with the audio I stripped from virtualdub.
What should I do?
Thanks a lot,
diego. -
Diego,
Did you use Full Processing Mode when you extracted the audio?Pull! Bang! Darn! -
Originally Posted by diegopies
Originally Posted by Suntan
Check your system log. If it is bad sectors, windows will make a note, something like unable to read, or unable to write. Also enable S.M.A.R.T. for your hard drive(s) and see what it says about the condition of them. -
I use to have the same problem. My CPU was overheating. I have an AMD processor, and AMD chips run hotter than Intel.
Open the case and blow off any extra dust around the CPU and the power supply fans. Also try turning up the A/C when doing conversions.
If you want to monitor the temperature of the MB and CPU there is a program you can download for free, called (of all things) Motherboard Monitor. Do a search to find it.Burn Baby Burn
It's a Disk-o Inferno -
You could take the case top off, point a room fan at it & if it works then you know its hot.
SVCD2DVD v2.5 Reboots PC
By ritzchef in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 20th Mar 2009, 08:29 -
System shuts down and reboots every 13 days?
By tinoman1 in forum ComputerReplies: 7Last Post: 28th Apr 2008, 00:04 -
pc reboots when wow starts up
By Mr anderson in forum ComputerReplies: 8Last Post: 26th Aug 2007, 07:01 -
pc reboots if i touch the case
By bigmicka in forum ComputerReplies: 10Last Post: 1st Jul 2007, 05:12 -
Machine reboots itself...
By The Fred in forum ComputerReplies: 17Last Post: 12th May 2007, 17:58
