Hello! im have a problem! i use to compress the movies i record, to SVCD in TMPGEnc, but now the SVCD filter in TMPGEnc has disappeared. So now i haft to pay for it.
Then i started to compress the movies to xvid ( thats the format i wanted them in the beginning, becuse i have heard that the quality can be really nice and that it dont take to much space).
But my xvid movies gets really bad.
My camera is a Panasonic NV-22, if that is some help.
Can someone plz help to understand how a get some nice quality. and i dont want the movies to take to much space.
i have heard that you can get really nice quality with xvid in Adobe Premiere Pro, but the program is so hard :/
(exuse my english, i hope you understand what i mean).
/Eriksson
ICQ: 103062213
Results 1 to 18 of 18
I'd love to assist you. The problem is that I don't know what you're asking. Do you want help using TMPGEnc? Do you want recommendations on other software encoders? Are you having problems with playback or encoding? Provide a little more detail and it'd be easier for us to help.
[i.am.quiller]
simplicity rules -
Find a good hardware mpeg2 capture card (I used a Dazzle DVC II), author it with Tmpgenc Author and burn it with Nero, a 2 hour movie takes about 2 hours 30 minutes from capture to author to burn. worked well for me for about 300 movies. Not sure if that was what you were asking.
(I prefer to skip the AVI to MPEG2 software conversion process) -
To make the question a little more understanding:
When i compress my movie i have record with my camera.
How do you guys think im gonna compress. to get the best quallity? and so it take so little space as possible. i want to compress my movies to xvid, but when i do it, does the quallity get really bad.
i want to have all the movies i record on my computer, to later, when im gonna clip togehter a movie./Eriksson -
I dont think I can help as I dont have a video or digital camera to use but I will try and explain what is required so all can understand if some people are having trouble.
I think this is what is wanted.
Eriksson has a camera (not sure if digital or analog).
Wants to capture or copy footage from camera to the PC. Wants to know basically what is the best file type to have the footage in so the file size is small but the quality is good.
Correct me if I am wrong Eriksson.
If the camera is analog then I suggest capture in avi (huge file size) but you keep the quality and it is best file for later editting. As far as I believe there is always a trade off. If you want the best quality you are going to need the file size.
I know alot will disagree with me but that is the nature of forums.
VHS is a dying breed
Sad but true. -
My camera is and Digital Videocamera, ( Panasonic GS-22 ).
i have no problem to capture the movies to the computer, i use WinDV.
i just asked if you guys did know witch format im gonna use (xvid,svcd,vcd) to get the best result and so it take little space.
Right now im have started to compress to SVCD./Eriksson -
when you compare the two, a DivX or XviD AVI will be much smaller given the same quality as MPEG-1(VCD/DVD) or MPEG-2 (SVCD/DVD).
Do you just want these to watch on your computer, or in a set top DVD player ?
If it is just for your computer, I would investigate the DivX/XviD options.If in doubt, Google it. -
im not really shore if i want it on DVD, or my computer
I thougt that i can do like this:
i compress all the movies a got into SVCD, and if i later want them in Xvid, i can just "recompress" them into Xvid?
But then i have heard that i can get bad quallity if i "recompress" SVCD into Xvid? is that true?
I dont mind if it quallity just gets a little bit poorer./Eriksson -
Yeah, but i need to know this first:
But then i have heard that i can get bad quallity if i "recompress" SVCD into Xvid? is that true?/Eriksson -
Did you have the trial version? If you did the mpeg2 feature is disabled after awhile to get you to buy the program unless you live in the future.Originally Posted by Eriksson
There always is a loss in quality when you re-encode, how much depends on how much you compress. You can probably compress an SVCD into divx-avi and get a file size about 1/2 of the original with quality pretty similar to the original.Originally Posted by Eriksson"Art is making something out of nothing and selling it." - Frank Zappa
Yeah, i did have the trial verison! i have think im gonna go with SVCD, becose, i can have on the computer, with out it takes to much space, and a can burn it to DVD, in niiiiice quallity ;D
/Eriksson -
Unless you buy the program, you cannot make svcds. The mpeg2 encoding feature expired.
DXVA not playing??????plz help
By ansonjoy in forum Software PlayingReplies: 7Last Post: 9th Dec 2011, 09:35 -
want to create a boxset plz
By Lugs in forum EditingReplies: 5Last Post: 15th Nov 2011, 20:23 -
How to playback BluRay plz ?
By Cov(enant) in forum Blu-ray RippingReplies: 2Last Post: 16th Sep 2008, 18:44 -
plz help
By sajjad223 in forum Video Streaming DownloadingReplies: 1Last Post: 4th May 2008, 11:12 -
VirtalDub ERROR - plz help
By UmmAddan in forum DVD RippingReplies: 3Last Post: 30th May 2007, 18:52
