Hi,
I downloaded 2 move files which have since been removed from the site.
I downloaded 2 files in the format avseq01.dat format which is 750MB. When i open it in WMP it says playtime is 1hr 10 mins and it runs for 1hr 10mins.
The other file avseq05.dat (not related to the previous file) is 732 MB. I got downloaded completey. When i opn it it says 1hr 05 mins as playtime but it only plays till 40 mins. Though the WMP counter says 1he.05 mins. After 40 mins it just freezes.
I know the file got donwloaded correctly and the size is correct since i have moved it to zip drives and then m harddisk and the file saize remains the same. It looks like the second file though downlaoded correctly has got corrupted, how do i fix it..
eddie
did you search the site?
https://www.videohelp.com/tools?tool=209#comments -
Tried it, does not work, usually WMP hangs after playing 40 mins, now it crashes with the messag saying memory referenced cannot be read
If the video is available commercially, buy it. Save yourself the headache of downloading crappy quality conversions.
Since we're assuming that the video is public domain, simply "find" it somewhere and copy it. DVD works best.
Problem is that this is a movie i found on the internet which i want (buy or whatever), when it starts there are no credits and it ends half way due to the corrupt file). I dont recognize any of the characters so cant get the movie name. I tried imdb search with the character name but with imdb you can put only one name and it gives tons and tons of results, so i either need to restore the file or find a way to figure out the movie name so that i can buy it.
Is there a site where i can find a list of all actors and atresses with their pictures, once i have that i may be able to use imdb to get the movie name..
thanks,
Chandan -
post in offtopic with a few frames from the film - you'll have your answer before you know it!
A corrupt file after sending a .3gp file via bluetooth
By ViDector in forum Video ConversionReplies: 3Last Post: 15th Aug 2011, 10:03 -
Recover .h264 file
By klode in forum Video ConversionReplies: 2Last Post: 23rd Sep 2010, 11:35 -
How Can I recover a .mp4 File?
By PUCH84 in forum Video ConversionReplies: 0Last Post: 25th Aug 2009, 17:46 -
Recover a program file
By BLSAMPLES in forum ComputerReplies: 5Last Post: 29th Jul 2009, 00:17 -
Help - Need to Recover Deleted ISO File
By mn072065 in forum ComputerReplies: 10Last Post: 22nd Apr 2008, 10:38
