A DAY AFTER Intel released five LGA 775 chips, the firm reported a list of bugs in its Pentium 4 Prescott produced at 90 nanometres.
The report, dated 22nd of June 2004, show some interesting examples of erratanotbugs. For example, R9 is described as "System bus interrupt messages without data which receive a hard failure response may hang the processor".
So far no workaround is available for this bug.
R16 describes a system hanging as a result of a fatal cache error, while R19 describes a parity error in the L1 cache which could cause the processor to hang. There's no workaround for this one yet, in this stepping.
There are bugs in all chips, although the more complex the design, the more bugs can be expected. The document Intel released on the 22nd of June describes both 478 pin and LGA 775 microprocessors. It's what's inside, not the packaging, which is important here.
The channel tells the INQ that there may not be as quite as many Prescott Pentium 4s around before September as we might expect.
So that gives Intel time to fix some of the errata found in the PDF, here, perhaps by attempting different so-called "steppings". µ
Probably has something to do with how hot those damn things run. They better fix it for the Nocona release today.
Intel Q6600 Kentsfield or Intel E8400 Wolfdale??? Help me decide which one
By budz in forum ComputerReplies: 33Last Post: 12th Mar 2009, 01:19 -
info on converting and editing numerous chapters
By nobbydadog in forum EditingReplies: 1Last Post: 28th Jan 2008, 14:53 -
Numerous access to a file ?
By Pnume in forum Newbie / General discussionsReplies: 0Last Post: 21st Jan 2008, 07:39 -
3.4 Pentium 4 or 935 Pentium D?
By DarrellS in forum ComputerReplies: 6Last Post: 12th Jan 2008, 00:58 -
GIGABYTE motherboard / Intel Pentium D 935
By thebirdf in forum ComputerReplies: 4Last Post: 2nd Nov 2007, 14:50
