So the situation is that I needed menus for some episode discs. I used DVD Decrytor to get it on my HD, and everything is fine. I then go to plug it in to TDA, which is where it gets funky.
On the screen where one selects the title it gives the right time. Click next 2 times over, and I'm back to the Source Setup page. But the Track has been cut. This only happens to the middle title. (3 Titles on each DVD). The cuts are significant going from 51mins to 30 something (30, 36, and 26).
At first I thought it would correct itself so I finish the process and let TDA encode. The output is the 30 something title.
Has anyone run into this before? I've done some searching and haven't run into anything close. I haven't tried anything other than TDA, bc it seemed to be the easiest but it may be the only choice. I know DVD workshop won't work (at least not the trial version) because of too many segements. I also trying to get dvdauthorgui to work but thats not a very user friendly program.
Results 1 to 1 of 1
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
TMPGEnc DVD Author 1.6 cutting a movie short?
By FizzFozz in forum Newbie / General discussionsReplies: 0Last Post: 21st Jun 2008, 12:20 -
TMPGEnc DVD Author 1.5 Problem... Only with these files... Weird, Help!
By acid_burn in forum Authoring (DVD)Replies: 3Last Post: 11th Jun 2008, 13:50 -
TMPGEnc DVD Author 3 no longer read .TS files?
By Nick Burns in forum Authoring (DVD)Replies: 3Last Post: 5th Nov 2007, 01:28 -
Problems with TMPGEnc DVD Author 3 and multiple AVI files
By cadkins in forum Authoring (DVD)Replies: 6Last Post: 9th May 2007, 15:37
