Copied to dvd from camcorder on my panasonic E50. The disc is dvd-r and is finalized. It Plays on my other players.
Wanted to make copies on Pc. Have used alcohol, roxio, Nero, Dvd decrypter etc all to no avail.
The disc says it has copied and appears to have all the info but will not play on any dvd player.The disc is recognised by the players but will not play.
can any one help
Redfoot
Results 1 to 9 of 9
Hmmm... I have an E50 and have frequently edited the DVD-R's it makes on the computer. I've used DVD Shrink to extract the VOB's with no problems. You could back up the DVD to your hard drive using DVD Shrink and then try burning copies from the back up file.
I've also used VOBEdit to extract/demux the VOB's into separate .m2v and .ac3 files. Then you could author a new simple DVD with IFOEdit.
Maybe give those two a try...
Also, since it is not a copy protected DVD, you should be able to make a disc-to-disc copy with Nero Express. That does not work? -
Thanks For the reply
The computer copied disc will play on the E 50 but not on any other Dvd Player.
any idea's
Redfoot -
The disc are Dvd-r discs (Ritec). the original copy will play on any dvd player. It is only when you copy on the computer it that it will not play on other Dvd players.
I Have a panasonic 106 and a panasonic 107 tried on both still no joy
Tried dvdshrink as you suggested still the same problem
Thanks -
Well, I'm stumped on this one. The media (Ritek) has worked out OK for other DVD's you've made?
best Buy dot com has ten Panasonic dvd-r disks for $5 after rebate, free shipping, right now for a few days. Try some of those.
When you used DVD Decrypter did you use the ISO mode or the file mode? You should be able to read then write in ISO. If you used file then you have to select all the files to copy to your hard drive to a VIDEO_TS folder. Then you could use a player like PowerDVD to test the files before burning.
VCR comparison Panasonic NV-FS200(AG 1980) VS Panasonic NV-HS1000
By JoseD in forum RestorationReplies: 32Last Post: 18th Apr 2016, 08:30 -
Panasonic DMR-EZ28 Previously Recorded Panasonic DVDs
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 6Last Post: 20th Oct 2008, 20:45 -
Panasonic DMR E50/E55 drive replacement
By zzucru in forum DVD & Blu-ray RecordersReplies: 3Last Post: 7th Oct 2008, 13:09 -
black bars on sides of screen, Panasonic s97 to Panasonic e55
By southland66 in forum DVD & Blu-ray RecordersReplies: 14Last Post: 10th Sep 2008, 17:15 -
looking to replace a panasonic DMR -E50 any ideas?
By edmond in forum DVD & Blu-ray RecordersReplies: 4Last Post: 27th Oct 2007, 12:34
