Hi,
I am also have Philips DVDR-615 with broken remote control. So there is my solution to close these dvd wirh "Nero Burning Rom 10.0":
Start NERO and close wizard
Go to "Recorder" menu
Select "Disk Info"
It shows for me 2 tracks (1-unknown, 2-data)
In he bottom and left side of the screen select drop down menu "DVD R Options"
Select "Close DVD VR"
Preass OK in the warning screen
That is all. After that i am able to play this dvd on PC or other DVD players.
PetrasL
Results 31 to 36 of 36
Ive found that when a non finalized DVD is moved to another machine, that machine needs to record anything ,even 30 seconds of anything,if there is room on the disc, then THAT machine will finalize the disc, my experience is only with stand alone DVD recorders,not PCs.I bought 2 magnavox DVD recorders with COMPONET video inputsmodel MRV 660. The last machine to record on the disc will be able to finalize it.Thats been my experience, many times. Mike
This thread is twelve years old and the person you are replying to is no longer active here. Did you not see the old thread warning? It is there to discourage needless grave digging. If you keep digging up old threads to add your two cents, expect to hear from a moderator.
Plus, not only is the advice you gave unlikely to work using a DVD recorder chosen at random, it is likely to make a the recordings on the DVD unrecoverable with ISOBuster or similar software by screwing up the file system. Having personally recovered recordings from a number of unfinalized discs with ISOBuster, I know that data recovery has a good chance of succeeding, as long as the file system is intact.Last edited by usually_quiet; 19th Dec 2016 at 13:32. Reason: grammar
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
^^ So you dig up a 4 year old thread (which is actually much older than that) to effectively say what was said in the earlier replies.
How to Finalize DVD Disc
By MI6 in forum DVD RippingReplies: 6Last Post: 22nd Jun 2012, 12:27 -
finalize DVD
By bobaumichedu in forum Newbie / General discussionsReplies: 10Last Post: 14th Sep 2011, 14:59 -
faulty DVD-R will not finalize
By joecass in forum DVD & Blu-ray RecordersReplies: 19Last Post: 10th Nov 2009, 19:51 -
DVD's/CD's won't finalize HELP
By dude-nl in forum DVD & Blu-ray WritersReplies: 19Last Post: 10th Dec 2008, 15:31 -
Finalize DVD-R PROBLEMS
By wswingsze in forum DVD & Blu-ray WritersReplies: 8Last Post: 13th Sep 2007, 22:12
