i want to create a backup for my 50 original vcd movies. ill just do a quick cd to cd copy using nero 6 with my ASUS 52X32X52 CD Writer.
since i need to finish the burning ASAP while i still have free time, can i do it in one setting, continously with out any break for my CD writer
will my CD writer give up or crank out?... is this advisable?
or shall i stop for example after 10 vcd and rest for 10 minutes then continue my burning?
what is your experience on this guys? what is the maximum number of vcd that you burned in one sitting? im just concerned for my CD writer coz i still don't have a budget to buy new one though its cheap...
I would burn maybe 10 in a row and then take a break cause the writer will heat up a lot depending on the enclosure its fitted into,too much heat will result in failed burns as reported by other people with the same situation you are going to go into.
If your pc is well ventilated I do not think you will have a problem.
I did around 180 once all fine, no errors with my old Misumi drive (and its still going strong). -
Originally Posted by d_unbeliever
BTW, are you making VCDs of whole seasons of your wife's Korean sitcom? She is quite a hotty ya know. -
i got 2 fans in my cpu, one at the back and one at the side, is this enough?
thanks for the advice guys, i hope others will also share their experiences on this...
888888BTW, are you making VCDs of whole seasons of your wife's Korean sitcom? She is quite a hotty ya knowi already have back ups of all the movies of my Korean's wife
i'm planning to divorce her in the near future tell the other guys they can have her
the backups im planning is for movies like lord of the rings series, charlie's angels, harry potter2, and other 47 original vcd movies... :P -
What is all this talk of koreans wife????????????
VHS is a dying breed
Sad but true.
vhs cassette not sitting down one side in vhs recorder ?
By oldfellow in forum Newbie / General discussionsReplies: 3Last Post: 12th Mar 2012, 15:23 -
Maximum Bitrate
By unity2 in forum Authoring (DVD)Replies: 17Last Post: 24th Jun 2011, 07:25 -
Problem with recording apps hanging after sitting idle under XP Pro.
By brassplyer in forum Newbie / General discussionsReplies: 1Last Post: 2nd Feb 2011, 07:22 -
BD-RE maximum writes?
By doppletwo in forum MediaReplies: 1Last Post: 8th Aug 2010, 22:59 -
uploading multpile files in one sitting ? ... [gave up on]
By vhelp in forum FeedbackReplies: 0Last Post: 18th Jan 2010, 17:37
