I have an image I'd like to use for the Menu 1 background. When I drag it to the Menu 1 item, it completely fills the entire window. It's my understanding that the inner white lines are the only part you're sure to see on the TV, and the next set of white lines is probably about where I'd want my image to be. I'm afraid a good 25% will be chopped off at the edges as it is now. I noticed when I right-click on the background, there's a "Change Size" option, but it's greyed out.
Another possible solution Google led me to would be to add a border to my image. I could find how to do that in Photoshop, which I don't have. If anyone doesn't know the answer to the first question but can tell me how to add a border with freely available software, that'd be great.
Click on the background image. Put the cursor at any corner and drag it in or out to resize. If you make the image smaller, it will add a black border automaticlly.
HD Animated Backgrounds etc
By jamesbustar in forum EditingReplies: 1Last Post: 7th Apr 2009, 08:31 -
dvd menu backgrounds..
By kanithan in forum Newbie / General discussionsReplies: 8Last Post: 10th May 2008, 09:25 -
X-mas DVD backgrounds
By tin2tin in forum Newbie / General discussionsReplies: 0Last Post: 20th Dec 2007, 04:03 -
backgrounds in XP Home
By snafubaby in forum Newbie / General discussionsReplies: 3Last Post: 6th Dec 2007, 04:04 -
Backgrounds
By boggle in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 2nd Jul 2007, 13:35
