I am really, REALLY new to burning DVD's. I bought a Panasonic DMR-E55 from Best Buy and I can't figure out how to finalize the DVD-R so that I can watch it on a different DVD player. Can someone here PLEASE walk me thru this? Thanks.
not to sound that rude, but how about reading the manual that came with it--
i have an e-100.. i also had a problem finding how to finalise the disc which led to loads of other problems including me thinking that discs id created would never work on anyones machine..
if your box, is similar to my box..
in DVD mode (not sure if u hav a HD)..try going to the functions menu..and going to disc info, while your semi finished disc is in the drive..
u should find an option to finalise the disc -
I did read the manual, but I can't figure out which menu the option to finalize it should be in.
LOOK ON PAGE 33 OF THE MANUAL. THE LAST SECTION IS TITLED FINALIZE. THESE ARE THE INSTRUCTIONS. I ASSUME YOU ARE USING DVD-R FOR THE RECORDING MEDIA.
BURT KRITT
picture control on Panasonic dmr e55
By mammo1789 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Jan 2012, 17:41 -
How to set correc IR (black level in panasonic dmr e55 and es15)
By mammo1789 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 13th Nov 2011, 10:42 -
PANASONIC DMR-E50P I forgot to finalize years ago and now can't play DVD
By JWWILSONMD in forum Authoring (DVD)Replies: 2Last Post: 30th Sep 2009, 19:29 -
Panasonic DMR E50/E55 drive replacement
By zzucru in forum DVD & Blu-ray RecordersReplies: 3Last Post: 7th Oct 2008, 14:09 -
Panasonic DMR-E55-E55S or E55K?1st DVD recorder/1st time posting
By ToeTagged in forum DVD & Blu-ray RecordersReplies: 7Last Post: 19th Jan 2008, 15:33
