  1. I downloaded a zip folder from medion to drive E(recover) and unziped it to dirve C (boot partition) this created the following files into a folder called 'medion'
    awfl8268.exe
    md8088.bat
    w7048im7.10a
    the instructions tell me to boot to dos from cd(which I can do) then
    'execute the md8088.bat file which can now be found at partition C: into your specified folder'
    only problem is I hav'nt a clue about DOS, can someone put me out of my misery and help out
  2. what is your C: partition formated as? FAT or NTFS?
    if it's FAT
    boot the DOS diskette or CD
    type
    C:
    cd medion
    md8088.bat
    if NTFS you will not be able to access them from DOS
    if so, place those files on a floppy first
    boot up from your DOS boot CD?
    after boot up place the the floppy in and type
    A:md8088.bat
    if you boot DOS from a floppy diskette
    after boot up remove the DOS floppy and place the other floppy in and type
    A:md8088.bat
    EDIT: you don't actually have a DOS boot diskette/CD lying around?
    Get one here http://www.bootdisk.com/bootdisk.htm
    Originally Posted by jagabo
  3. thanks very much
    C is NTFS, but E is FAT32 . will move files and try your commands( will alter drive name)
  4. Originally Posted by JOHNO1
    thanks very much
    nope, DOS wont see the NTFS so the first partition is finds it will label C:
  5. cheers stiltman...managed to update Bios last night
  6. good deal, glad it worked for you
