I recently made a dual audio SVCD with subtitles. Now, on my player both audios work, however the subtitles will not play. This may be because I made the SVCD incorrectly. Is it common to assume if the player plays dual SVCD tracks then it can play the subtitles too? At any rate, I was wondering if there was a program I could use to test the SVCD and see if the subtitles work? Thanks in advance
You can burn the svcd to an image file, then mount the image to a virtual drive using Damon tools, and then play it on a software dvd player and see if it works.
The only software DVD player that supports soft encoded subs in SVCDs is the latest version of media player classic. I also recommend creating and mounting an image and playing it like that.
All SVCD compatible DVD players are required to play 2 stereo or 4 mono audio tracks. Subtitle support, on the other hand, is completely optional and most hardware players don't support it. There are two different subtitle formats though, SVCD and CVD. CVD is actually more compatible overall, but you should try both to see which one works best on your player, or if either is supported at all.
How to convert mkv files and keep dual/multiple Audio Tracks?
By MrNathanF in forum Video ConversionReplies: 2Last Post: 19th Jan 2012, 11:34 -
Ripping dual audio tracks Karaoke DVD
By Longhorn1955 in forum Newbie / General discussionsReplies: 3Last Post: 8th Dec 2011, 00:14 -
How to make dual mp3 tracks
By NotoriousGRK in forum AudioReplies: 3Last Post: 23rd Jan 2011, 20:21 -
Dual Audio Tracks Playing After K-Lite Codec Pack
By Boris_yo in forum Video Streaming DownloadingReplies: 9Last Post: 7th Jan 2011, 07:57 -
looking for program to play audio tracks from MKV
By funky777 in forum Newbie / General discussionsReplies: 1Last Post: 5th Mar 2009, 22:41
