Does anyone have, or know where to get WinAVI trial version 5.5, I can't find it anywhere and am having probs getting 5.6 to run. Can anyone help out?
thanks
contact these people would be my first recommendation:
http://www.winmpg.com
http://www.winmpg.com/download.html
only place i see 5.5 still on the net other than above is http://www.divxarea.com/downloads.asp?id=213
but a little more google work may turn up other places ...."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Thanks, but I am after WinAVI not WinMPG, I think they are different progs, those links are down anyway.
Just try WinAVI v5.7 beta2 test version, it fixed all the bugs we have known. You can get it from:
http://www.winavi.com/WinAVI57_beta2.exe
If you find any problem, please contact us: support@winavi.com
Looking for a trial registry cleaner!!!
By kemcel in forum ComputerReplies: 13Last Post: 30th Oct 2008, 01:50 -
Thoughts on Tmpgenc Express 3.1.5.82 Trial
By Batfink in forum Video ConversionReplies: 15Last Post: 30th Oct 2007, 01:17 -
Premiere Pro CS3 trial
By MarioB in forum ComputerReplies: 1Last Post: 19th Oct 2007, 09:25 -
how long does the Trial for Vegas last?
By LITEONDVD in forum EditingReplies: 2Last Post: 3rd Sep 2007, 13:00
