I recently came across a .rar file which contained the .bin and .cue. I read a guide here and it was very helpfull for me to view the file and everything worked well. Now my problem is getting it to DVD. This is the guide I used and I have every program that member suggested and tried to follow the steps exactly https://www.videohelp.com/forum/viewtopic.php?t=221369. I just now need to get the .rar onto a DVD. Any help would be greatly appreciated.
Results 1 to 9 of 9
you mean get the mpeg file onto a dvd -- it would help to know what type of mpeg (or other) file you got there after extraxcting it from the rars ...
type meaning =
file type
resolution
frame rate
audio sample rate and type
then you may have to do some encoding or some other steps first .. then you will have to author a dvd - then you will have to burn a dvd ...."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Sorry. Will this help?
EDIT:Guess I can upload pics yet
Video
Frame rate: 25.000
Frames: 84016, length 56mins
Audio
Sample rate:44100
Sample: 148205952,
Bits per sample:16
Channels: 2
DVD, 720x480 pixel, 29.97 fps, 48000hz, 2 channels, 16 bit -
looks like you have a PAL svcd and you want to make a NTSC dvd
so you will have to convert both the audio and video and the frame rate and such ....."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Do you have a recommdation on which program to use? And any guides here on the site that I could check out.
Just burn the bin/cue file with nero burning rom or cdrwin or alcohol 120%,its a svcd pal which can played on most dvd players in the last 2 years.
Originally Posted by johns0"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Not really BJ_M
I can play pal svcds in my dvd players, and I live in the USA. -
I think what he meant is that most newer players can play both NTSC and PAL and convert the signal to match the TV.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 11:58 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
