Hey all!
First post here, hope I posted it in the right forum.
Anyways... I have a couple of DivX movies which I want to put on DVD. I also have the corresponding subtitles (in .sub format) which match with the DivX movie (just one language).
Now, I'd like to create a DVD which has like... 3 DivX movies and the subtitles. And I'd also like to be able to create a menu so you can pick which one of the three movies you want to see. And, if possible, also the ability to put the chapters at the places I want them to be.
Is this possible?
So far, what I did, is this:
First I used DVD2SVCD to get 1 DivX movie and make it a DVD with subtitles. I do this for all 3 DivX. So, then I have 3 DVD-movies (in DVD-Video format). Then I use something like Nero Recode and add the three movies to create 1 movie and keep the subtitles. However, if I do this, I don't have a menu yet nor can I set the chapters.
Who knows a way how I can add 3 DivX movies to a DVD, add subtitles to the DivX movies and add a menu and chapters?
convert to dvd mpeg with an mpeg encoder and then author with dvd-lab pro or dvdauthorgui, they support switchable subtitles.
Creating a DVD Menu for multiple divx files without converting them
By LGT in forum Newbie / General discussionsReplies: 23Last Post: 21st Jul 2010, 15:04 -
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 09:27 -
How to convert multiple avi's to DVD with chapter points between each?
By Pierre1 in forum Newbie / General discussionsReplies: 3Last Post: 6th Aug 2009, 08:38 -
How to create a DVD using multiple DIVX/XVID files with Menu
By Amourek in forum User guidesReplies: 2Last Post: 2nd Mar 2009, 09:57 -
DVD Menu with Chapter and Menu Template.
By big-boo in forum Authoring (DVD)Replies: 3Last Post: 17th Mar 2008, 07:20
