  1. Member mar-mar's Avatar
    Mar 2003
    between here and there
    i've been readin up on firmware little bit thru the site and all but im a little confused. im using a nec -nd1000a dvd+rw drive and flashed with 1.01 but now the dvd plays but i can't burn cdr or dvdr properly it would go to about 50% complete and then terminate burn or i would burn on a lower speed where it would finish succesful but the disc would be trash , i did a simulate test and that works perfectly to 100% succesful but just doesn't on actual, can firmware or say bad flashing be a cause of this or could the burner be shot
    http://www.dondivamag.com
    :) This site is the Best thing since slice bread :)
  2. Member mar-mar's Avatar
    Mar 2003
    im stuck at this point ,what do i do?
    May 2003
    Manchester, England
    If it was fine until you upgraded your firmware, I'm pretty sure that's most likely the problem.
    Can you downgrade it?
  4. I would say re-install the firmware without a disc in drive and see if that fixes it.
