**updated**
Hey all,
Ok, I posted here yesterday asking about how I could burn and cram a bunch of my cd+g cd's onto a DVD. Well, I found out that my cd drive can write and rip CD+G cd's with no problem; and I am able to rip in CDG or BIN or whatever format i need -- which is good...
One method I read about was to convert the cd+g (bin) file into an mpeg or avi and then burn that to a DVD. Much to my surprise, the average song in .mpeg format is 300 megs. Which would only allow about 17 on a DVD+R, which is pointless because i might as well just use my original CD+G -- i am not gaining any storage capacity.
I am surprised that no one has come up with a way to just toss a bunch of ripped cd+g images and burn them to a DVD.
If i took a bunch of burned BIN files and filled a DVD with them, I would think that the DVD player (which is CD+G compatible) would simply play them as usual, but i have heard that the way the DVD player reads the discs, it will not read them correctly.... Or will it....
I wonder what would happen if I made complete image files of several cd+G cd's then turned around and burned those multiple images onto 1 DVD…..
What have some people tried that did and/or didn’t work?
Hopefully we can come up with some way of being able to store a bunch of CD+G files/discs on a DVD -- which would be real convenient. Please let me know if you guys have any experiment...
I appreciate your help....
Thanks,
M
(Magicianstalk@hotmail.com)
Had anyone updated their Liteon 5045 or other standalone to SATA DVD ?
By bithead9 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 29th Nov 2011, 19:31 -
Advanced High Definition Video Disk Creator v2.9B(AVCHD DVD) UPDATED
By Gherudos in forum Video ConversionReplies: 31Last Post: 3rd May 2011, 10:10 -
question about HD-DVD burning
By kditty in forum Newbie / General discussionsReplies: 3Last Post: 7th Nov 2007, 11:21 -
Authoring a DVD with updated audio files
By Turbo Sensonic in forum Authoring (DVD)Replies: 2Last Post: 28th Jul 2007, 07:25 -
After Burning a DVD question
By boomers03gmc in forum DVD & Blu-ray RecordersReplies: 3Last Post: 19th Jul 2007, 03:25
