Hi, hope someone has an answer for me.
I'm trying to rip a movie but I get sector errors when using either DVDDecryptor or DVDShrink. The DVD disc does have scratches on it which is what I think is causing the problem. I'm able to play the DVD on Cyberhome DVD player but not on computer.
Any suggestions on how I can rip the movie?
Thanks in advance.
Do a search for "Brasso" or "Toothpaste"
Not joking either...
Both products work well at enabling you to remove marks and scratches..Not bothered by small problems...
Spend a night alone with a mosquito -
It's a common problem. Even if you could read it, the errors would still be there. As iooi says, polish them out. If they are minor, some people have had luck with just washing them in warm water and applying a light wax to fill the minor scratches. I saved my only copy of XP that way. Took about 30 minutes of careful buffing to clean up a big scratch. Crossways, not circular.
Similar to the advice already given. I used a candle on a badly scratched disc and managed to rip it.
Rub the candle all over the disc and smooth out the wax.
The first time I tried I removed far too much wax (great shine on the disc though) and still got errors.
The second time I was a little less careful (disc was dull and I only spent a minute to clean off the excess) and got a great result . -
Thanks for all the tips.
As for the toothpaste, does it have to be any particular kind like "whitening", Tar Tar control" or any regular toothpaste will do? -
Personally i just use a plain white tootpaste "Colgate" find it better than any that have loads of colours in them.
Plain white toothpaste.
PASTE ONLY. No "whitening" ingredients, and for God's sake NO BAKING SODA. You're not trying to rub THROUGH the disc. LOL.
- Gurm
how to RIP/COPY dvd with bad sector??
By ysfm in forum DVD RippingReplies: 5Last Post: 25th Feb 2011, 00:00 -
DVD Scratches HELP
By Goonies in forum Authoring (DVD)Replies: 1Last Post: 27th Jan 2010, 13:46 -
hp dvd 1040i, hp simple backup, error message:sbwin32.exe has generated err
By 84transam in forum DVD & Blu-ray WritersReplies: 4Last Post: 8th Jan 2008, 13:18 -
[ERR] GOP size is over the buffer limit - Compiling in DVD-lab PRO 2.30
By Wolverene in forum Authoring (DVD)Replies: 7Last Post: 31st Aug 2007, 22:55 -
How to avoid data burn to bad sector of CD/DVD RW ?
By kclgad in forum MediaReplies: 1Last Post: 31st May 2007, 07:17
