I am having problems editing some footage i captured. The footage i captured is 29mins long, and runs fine on Windows Media Player. However, when i come to edit in Premiere 6, i preview the footage and its lost around 20 frames per second !!!!!
So, i try and save it. Then watch it on WMP, and it is about 3-4 fps !?!?!
Can somebody please help.
rankz
Hi, Are your project settings correct ie. Pal not NTSC - Frame Rate 25 fps and not 30 0r 29.997fps?
Barry -
yeh. its in PAL and 25 fps.
I have the same problem with another clip i tried. that was same settings 2.30 mins longrankz -
Why use premiere to edit video? Are you adding transitions and stuff? If all you want is to cut a few scenes out, use Virtual dub instead
i'm not using Virtualdub because i want to delete most scenes, and only keep a few. then i want to re-arrange them and add backing music. So i find Premiere easier to use for this.
rankz
Bad quality WMV - will a conversion increase quality?
By nickbrace in forum Video ConversionReplies: 4Last Post: 20th Oct 2011, 04:48 -
Adobe Premiere Deinterlacing/youtube/HDV quality problem
By qatzo in forum Newbie / General discussionsReplies: 21Last Post: 4th Jun 2011, 13:12 -
Mp4 format problem, the vid have a bad quality after i rendered it.
By aisple_aislesz in forum Newbie / General discussionsReplies: 12Last Post: 25th Apr 2011, 10:02 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
Bad video quality when encoding in Premiere Pro CS3
By Rocky88 in forum EditingReplies: 2Last Post: 5th Sep 2007, 23:56
