Need help guys, i tried to capture VHS tape using video line-in to DV Camcorder, the from DVCam into PC. I'm using either Windows Movie Maker and Ulead Video Studio in capturing the video in DV Quality. I don't have problems capturing from DV to PC, but only when it's from a VHS Player. It's fine when i'm previewing the vhs playback on my pc, but when i push the record button, it automatically records the DV tape which is inside the DV Cam instead of the analog signal which coming out from the VHS playback. How could i solve it??? It seems that the DV playback synchronize with the recording buttons of the pc.
Not all DV cams support pass-through for recording. Of those that do, it is usually necessary to remove any tape from the Cam. Try that.
Yup, thanks, that did do it
but windows movie maker can't, at least in Ulead it works ...... Thanks Again!!!
Split video signal from single source cam
By TonHak in forum Capturing and VCRReplies: 6Last Post: 12th Aug 2010, 05:59 -
How do analog repeater stations get their signal?
By cal_tony in forum DVB / IPTVReplies: 1Last Post: 22nd Feb 2009, 13:04 -
Disapperaing analog cable channel on a split signal?
By yoda313 in forum Newbie / General discussionsReplies: 3Last Post: 6th Apr 2008, 10:42 -
Streaming More then one analog signal to your computer?
By Maknificent in forum Capturing and VCRReplies: 8Last Post: 26th Oct 2007, 20:02 -
How do I convert streaming video to an analog A/V signal for RF modulation
By mdavideo in forum ComputerReplies: 1Last Post: 8th Jun 2007, 21:42
