i have several OGMs each with two audio channels and switchable subtitles (.ssa). what i want to do is make a dvd so that i can pick between the 2 audio channels and switch the subtitles on or off. anyone know a good guide for this because the only ogm guides i seen so far only explain how to use 1 audio channel.
any help is appreciated.
https://www.videohelp.com/forum/viewtopic.php?t=222005
this guide will show you how.
skip the steps for adding permanent subs
follow the guide exactly except when it comes to authoring your dvd. Use dvd-lab or dvd-lab pro instead of tmpgenc dvd author. these authoring programs support multiple audio and switchable subs.
in the guide, i show how to demux only one audio stream, but just repeat the process for each audio stream you would like. you should end up with an m2v file, two ac3 files, and a subtitle stream.
you can add each stream into dvd-lab pro and it will allow you to switch audio/subtitle streams.
Multiple audio, subtitles, OGM, MKV & RMVB issues
By bkfng in forum ffmpegX general discussionReplies: 12Last Post: 17th Jan 2011, 00:05 -
Playing Flac to Multiple Channels
By patmann03 in forum AudioReplies: 0Last Post: 7th Sep 2010, 21:47 -
Converting .ogm to mpeg-4 with subtitles and multiple audio tracks
By Weasel3689 in forum ffmpegX general discussionReplies: 1Last Post: 23rd May 2009, 12:34 -
DVD record multiple channels?
By bobful in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jan 2009, 20:10 -
Switchable audio streams in DVD Lab Pro
By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 9th Mar 2008, 11:54
