I don't know what I have done wrong, but some XVID avi files will not
play correctly with WMP anymore. The picture is frozen and the audio is playing at 5 times the normal speed. If I play the same file with VLC it works just fine. What is the problem? What am I doing wrong?
GSpot tells me I've got 2 compatible video codecs installed and also the rendering is successfull. So, why is it behaving this way?
Should I uninstall and reinstall the codecs? In that case, which ones are the best to use?
Grateful for your help,
The Larch
VLC uses it own codecs while WMP uses directshow codecs so it is possible that your direct show codecs are screwed up, but I'll venture to guess it is a WMP screwup.
If anything the thing you are doing wrong is using WMP. Try Zoomplayer, if they play incorrectly with zoomplayer then you know it is the codecs.
-Suntan
XviD video playback problem
By mictsekk in forum DVD & Blu-ray PlayersReplies: 5Last Post: 20th Jul 2009, 10:16 -
Xvid Playback Aspect Ratio Problem
By midders in forum Video ConversionReplies: 3Last Post: 1st Apr 2009, 14:24 -
Xvid and Divx playback problem on TV set
By herbapou in forum Media Center PC / MediaCentersReplies: 3Last Post: 7th Sep 2008, 12:17 -
Interlaced XViD playback on Standalone - Field Order Problem
By nbarzgar in forum Video ConversionReplies: 2Last Post: 13th Jul 2008, 07:04 -
Sound Problem During Playback (XVid, DVIX etc.)
By Pyrolisk in forum Newbie / General discussionsReplies: 5Last Post: 21st May 2008, 11:00
