I have capture my MinDV in AVI format and try to make a DVD. I try to use the Mainconcept and TMPGEnc Pro encoders to do the conversion and none of the result is even close to the orginal AVI file. Especially when you play the movie frame by frame, the encoded frames are all fuzzy in edges.
Is there a professional version of encoder software that can make the DVD quality close to the commercial DVD?
