i use the hollywood drivers and station player with this creative decoder
board. playback is fine on the monitor. when i switch to TV-out
the TV picture shows this weird blotchy coloring which is particularly
noticeable in dimmer regions of a scene. it appears that colors are
being crudely rendered. for example a face may show 3 or 4 bands of
hues for skin color.
what is more perplexing is that this seems to happen often but not
all the time. i force TV-out to NTSC but the problem occurs whether
i play NTSC or PAL DVDs.
I have a DXR3 in a PIII-S PC (Via based Mobo). I’m using the latest Real Magic DXR3 drivers, W2K SP2, 512 MB RAM (PC133).
Sometimes I use this card to play a Pal DVD or MPEG pal files in NTSC format and capture it in my other PC. I have not been able to duplicate the problems you are referring.
Do you have the same problem through S-Video and Composite connection?
mpeg-2 decoder. What determines which one is used ?
By davexnet in forum Software PlayingReplies: 2Last Post: 22nd Jul 2009, 13:05 -
Problems installing Sony advanced MPEG encoder board.
By bidomo in forum Capturing and VCRReplies: 5Last Post: 9th Jul 2009, 11:15 -
Microsoft mpeg-2 decoder problem
By ivanpop in forum Software PlayingReplies: 10Last Post: 27th Feb 2009, 09:10 -
Combining PowerDVD 7's Audio Decoder and Microsot's MPEG-2 Video Decoder
By Dark Alpha in forum Software PlayingReplies: 4Last Post: 11th Sep 2008, 18:44 -
default MPEG-2 decoder?
By iThinkYouBrokeIt in forum Software PlayingReplies: 6Last Post: 6th May 2007, 18:49
