If TMPGEnc freezes or crashes when converting or you receive errors such as
Unexpected decimal point calculation
Illegal floating decimal point calculation order
Write error occured at address 77F83AED of module "ntdlll.dll"
Try first to change the directshow codec reader priority settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 2 or to the top of the plugin-list and try reopen the video.
If that doesn't help try repair/fix the video source, you find video repair/fix guides here (Downloaded video files could have bad/corrupt video frames that could cause crashes).
Ok, so when I click start it says
"Read error occured at address 00012F40 of module 'TMPGEnc.exe' with 20656850."
-Directshow media filters are the highest priorty
-I checked the file in virtualdub, its flawless no errors
any other possible causes to this? Thanks in advance
Are you frameserving the file from VDub or just feeding the raw source file to your encoder?
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
Read error with TMPGEnc
By MasterScreech in forum Authoring (VCD/SVCD)Replies: 2Last Post: 24th Jun 2010, 20:08 -
TMPGEnc Read Error
By koberulz in forum Video ConversionReplies: 0Last Post: 6th Nov 2008, 22:44 -
Is This A Common Problem? DVDr to AVI
By innovyse in forum DVD RippingReplies: 1Last Post: 21st Jan 2008, 06:09 -
TMPGEnc DVD Author 3 no longer read .TS files?
By Nick Burns in forum Authoring (DVD)Replies: 3Last Post: 5th Nov 2007, 01:28 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 18:59
