Has anyone ever used MainConcept to Capture and Encode to MPEG2 RealTime?
I do conversion from DV to MPEG2 with Mainconcept. Have done several old VHS tapes with a ADVC-100. This isn't capturing though, just on the fly encoding.
I use it all the time with a bt8xx card and with a nvidia card.
The latest version 1.4.2 is better the previus versions.
The results are great, but there are some bugs or maybe they are limitations of the program.
For example: When you capture at a framesize smaller than 720 x 576/480, a "statering" appears at the bottom of the screen. That has nothing to do with your target framesize. What I mean:
If I capture with my bt8xx card and the btwincap drivers at 768 x 576 (or with my nvidia card and 1.08 drivers at 720 x 576) and encoder realtime to 352 x 576, the picture is excellent and with not statering. Amazing results.
But when I capture at 352 x 576, the picture has that statering at the bottom of the screen.
Also, you need a modern CPU, more than 2 Ghz for the best possible results. It is not nessesary, but it helps (I manage to capture 768 x 576 and encode realtime to 352 x 576 VBR with a Duron 1200, but I set up my PC only for this task, after a great period of trial and error)
Real time ac3+ transcoder?
By andyhuk in forum AudioReplies: 1Last Post: 13th Jul 2011, 23:14 -
Low CPU Real time Video Encoding
By striker9 in forum Video ConversionReplies: 4Last Post: 27th May 2010, 11:54 -
Real time recording
By slaak in forum Newbie / General discussionsReplies: 0Last Post: 9th Feb 2010, 23:27 -
Real time video capturing
By Haopengyou in forum Capturing and VCRReplies: 3Last Post: 5th Aug 2009, 02:02 -
Capturing real-time 3D (games etc) for transfer to DVD
By Overwind in forum Newbie / General discussionsReplies: 1Last Post: 3rd Nov 2007, 05:33
