I'm trying to convert RM to SVCD and DVD. I have tried AVOne and EO Video with mixed results.
AVOne gives me good results sometimes. The main problem is the SVCD and DVD audio and video being out of synch when I convert some RM files. Also I have had problems with the program crashing on some RM files and, naturally, not being able to convert them at all.
EO Video seems to go a much better job, but the files tend to be overly large. I have found that the best results in terms of qualityand reasonable files size are to be had by choosing variable bitrate, but the files are stilll large and I do not know of a reasonably easy and inexpensive way to convert to DVD from the SVCD files from EO video. I believe TMPGEncoder will do this but my trial version will not do this and it seems the cost to buy the program is $68.
In a nut shell, is there a better program than AVOne for converting to SVCD and DVD that AVOne? Is there a simpler and cheaper way to convert the EOVideo SVCD files to DVD so that I can get a reasonable amount of video in terms of minutes on one disc (DVD, that is)?
Also, in EO Video when I choose automatic or specify a fixed bit rate, the files are the same size regardless of the bit rate chosen. ???? Why is this?
Any help would be appreciated. Thanks.
I use WinAVI from www.winavi.com. It has converted everything I have tried, even those that nothing else would touch. Yes, I have converted RM files with it.
Help needed Converting to AVCHD to play on Panasonic TV
By LOWTECH in forum Video ConversionReplies: 8Last Post: 31st Aug 2011, 12:52 -
help needed converting and editing an flv please
By Witzend in forum Newbie / General discussionsReplies: 6Last Post: 23rd Aug 2011, 15:04 -
trouble converting/xb360 essential settings needed
By Captain Slow in forum Newbie / General discussionsReplies: 8Last Post: 17th May 2011, 19:14 -
Help converting YUV420 to RGB565 needed
By cheetahace in forum ProgrammingReplies: 3Last Post: 18th Apr 2008, 02:15 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
