In most articles that ive read about converting from any AVI to DVD it says to use a program like GSpot or AVICodec to get info like fps, vid res, aud sample but ive never seen any explinations on why.
Do you want to try and keep about the same numbers in the DVD as there were in the AVI?
Of course isnt the fps going to change if its converting from PAL to NTSC?
Im pretty much ignorate when it comes to all this and wish I could find a step by step instructional of converting AVI to DVD as spoken to a newbies newbie.
I usualy just convert my downloaded avi and convert using Nero 6.3 but think I could get better outcome if I became more advanced at the whole process.
Thanks, from a newbies, newbie.
I'm a victim of circumstance
The reason AVIcodec or Gspot is suggested is that 'AVI' can mean quite a few different formats and different methods are used to go from AVI to DVD. I personally like TMPGEnc DVD encoder. Fairly easy to use and reasonably priced. Take a look at this guide, may be what you need.https://www.videohelp.com/tmpgencdvd.htm Also look at the 'What is' to the left under DVD and you will see what the requirements are for a DVD.
Thanks for pointing me in the right directions.
Im still somewhat in the dark about certain aspects of the whole process of converting from avi to dvd.
Most articles dont always go into enough detail. They tend to be written for people who probably know somewhat more than me.
I start following the steps and get off course because its over my head.
Maybe I should take up basket weaving or something. hehe.
Anyway, thanks so much. I will keep reading and following.......verbaten.I'm a victim of circumstance -
So it looks like you have to convert bitrate among other things but what about if its PAL (25fps).
Do you convert that to NTSC(23.976) which conforms to my area?
I havent read anything that covers that,
only Aspect Ratio, the audio info. and the duration of the avi.
I will say that I am getting the hang of it all.
Had an avi that played great on the pc but when I converted to DVD and played it, the sound was out of sync.
I seperated the audio and video, made the audio AC3 and put it back together with perfect results.
Anyway, thanks for any info on the above question.I'm a victim of circumstance -
Only if your DVD will not play it. I'm in North America and my DVD player will play a PAL disk.Originally Posted by tmgrood"Art is making something out of nothing and selling it." - Frank Zappa
Simple MKV file and info given -Need it in AVI
By cyberlion in forum EditingReplies: 2Last Post: 15th Aug 2010, 06:29 -
How do you find video info from partial avi?
By JoeBolden in forum Newbie / General discussionsReplies: 7Last Post: 14th Apr 2009, 20:48 -
[INFO] Embedded subtitles in .AVI files
By Midzuki in forum SubtitleReplies: 0Last Post: 24th Jan 2009, 01:17 -
Extracting Closed captions info from AVI
By arikp in forum Video ConversionReplies: 1Last Post: 16th Jul 2008, 13:16 -
info on converting and editing numerous chapters
By nobbydadog in forum EditingReplies: 1Last Post: 28th Jan 2008, 14:53
