  1. I'm planning to move one on my machines to linux and being a complete noob with it, I was wondering easy video processing ( capturing, backup, vcr-> dvd, all aspects) is compared to Windows. I don't mind a learning curve and having started in DOS. i'm not afraid of a command line (just out of practise), But I want to kow if it is doable. Thanks Nyah Levi
  2. Linux is a great OS, but I remember it being very hard to set up video4linux (needed for webcams/tv tuner/analog to digital) when I tried a year ago. In then end, I was able run my VCR through my webcam and watch TV on my computer (with help from some friendly linux experts).
    I am not sure how different it is to do this today, but if you can use linux, its a more powerful system than windows. There are many websites where you can get started (I dont know if it still exists in its same form, but http://www.linuxnewbie.org was helpful years ago).
  3. the best way is to try yourself,
    i dont use linux much these days, i just got tired of trying to remeber
    the names of programs.
    NO CONNECTION AT ALL TO WHAT THE PROGRAMS DO !?
    any way, i found some page with info about this,
    read here >> http://gecius.de/linux/dvd.html
    good luck
    HELL AINT A BAD PLACE TO BE
    Apr 2003
    I use ffmpeg to capture to avi/vcd/svcd/raw format.
    I use Avidemux to convert & edit the video clip to the required format vcd svcd or DVD.
    If burning a vcd or svcd I use k3b to burn.
    If burning a DVD I use qdvdauthror.
    So yes it is possable to do all in Linux.
    P.S. I use Mandrake. It setup my tv capture card without any hassles. I found it easier to setup with less problems than WinXP which didn't reconize my tv card and has crashed on me during a video capture.
