I tried the BeSweet and the GUI to create AC3 files from my AVI captures.
When I run it and check the log it says unrecognized format. I am capturing in PCM 48Khz, 192kps. (8mm anlog mono home movies)
How do I make BeSweet work? Is there another app I should be using? I want to create the audio directly from teh AVI.
Capture with IuVCR @ Half D1 PicVideo 18 (no dif between 18-20 that I can see)
Encode with AVISynth to TMPGEnc 2xVBR. 1000, 2200, 3500.
Or should I just let TMPGEnc create the audio and do MP2 instead?
LS
Results 1 to 10 of 10
That would depend. Is your player capable of MP2 playback? What country are you in?Originally Posted by LSchafroth
Knowing the answers to those two questions could greatly reduce any headaches. You may not even need to bother with AC3 at all. If you do still need AC3, then I'd recommend you try TMPGEnc's AC3 encoder. People are divided on BeSweet's output and the resultant files are questionable as to their compatability. TMPGEnc's AC3 encoder is $30 or so. You might want to consider that as an albeit not freeware encoder but cheap (~$970 less than) compared with any other Dolby certified product. -
So are you saying that you are loading the avi as your audio source? Well Besweet is an audio encoder not an avi parser. You need to extract the audio from your avi first and load that. It takes about 30 secs and the audio remains unchanged.
Just use VirtualDub. Load the avi, set the audio tab to direct stream process, then hit file/save wav.
BeSweet totally changed its AC3 encoding engine in the latest release. Its much more compatible now. -
I put it in there and got the same error:Originally Posted by thor300
Error 58: Error : Unknown Input-File Format :
LS -
Installing Besweet GUI on computer running Vista
By Lynxer in forum Newbie / General discussionsReplies: 10Last Post: 20th Apr 2011, 06:29 -
besweet, belight
By volam in forum AudioReplies: 0Last Post: 9th Sep 2009, 21:53 -
GUI Author & ISO
By chronic777 in forum Authoring (DVD)Replies: 8Last Post: 14th Jul 2008, 04:14
