I am using CopytoDVD since it usually works the best, but when I browse to the IFO, it wont work, something about a bad media structure. Is there some way to fix this?![]()
try opening the BUP of the same name. BUP stands for Back UP and is just a backup of the IFO file. If that doesn't work you can rip it with DVD decryptor in File mode, and use IFO Edit to build new IFOs for it.
File mode? I have DVD Decrypter but I thought it went from DVD to disk, please explain how I would do such thing.
If its a single layer disc, easiest way is to use DVD Decrypter in ISO read mode to make and image file and ISO write mode to burn it back to disc. If its a dual layer you can shrink it with DVD shrink instead. I don't think a whole lot of people use Copy to DVD
.ifo/.sup subtitle pair - what's in the .ifo?
By MilesAhead in forum SubtitleReplies: 2Last Post: 4th Mar 2010, 23:02 -
How to repair dvd with corrupt sectors AND bad video_ts.ifo?
By Spixe in forum Authoring (DVD)Replies: 8Last Post: 25th Jan 2010, 07:54 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
Bad motherboard or bad CPU?
By videohalp in forum ComputerReplies: 11Last Post: 9th Jul 2008, 10:07 -
4 separate IFO files > one IFO to govern the full .VOB video
By Salva Veritate in forum EditingReplies: 4Last Post: 20th Aug 2007, 13:38
