I can't seem to open an ogm file, I get an error, it says:
Could not construct a graph from this file.
-Have you installed all the necessary filters?
-Note that the 'Render File' menu option cannot render *.GRF files.
Cannot play back the file. The format is not supported. (Return code:0x80040265)
I used to be able to open them. Then I think i messed it up insalling some player. At any rate, Gspot says i have the correct codecs installed, however, the rendering fails.
It will play in media player classic, I can switch between audios, however the subtitles do not work, I can't turn them on.
If anyone can help i would really appreciate it. Thanks in advance
Sounds like you need to reinstall OggDS. Media Player Classic has a built in Ogg Splitter, and will allow you to open *.ogg, or *.ogm if you don't have the Ogg DirectShow Splitter installed.
The Ogg DirectShow splitter is required by GraphEdit.
You might already have the Core Vorbis filter installed, but if you reinstall OggDS it will still be the preferred filter (unless something has changed).
As for the Subtitles, you have to set the proper "Options" in Media Player Classic.
OggDS is a Splitter / Decoder combo.
Core Vorbis is only a Decoder filter.
XVID/mp3 file wont open in TMPGENc express
By efiste2 in forum Video ConversionReplies: 5Last Post: 14th Jan 2010, 17:16 -
Downloaded movie wont open..
By bahnan in forum Newbie / General discussionsReplies: 7Last Post: 20th Jun 2009, 11:56 -
Help the prgramme wont open!!
By amber123 in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 23rd Apr 2009, 07:51 -
GraphStudio - open source update of GraphEdit
By joepic in forum Video ConversionReplies: 1Last Post: 22nd Sep 2008, 13:44 -
.mov wont open in quicktime
By lonewolfsas2k4 in forum Newbie / General discussionsReplies: 1Last Post: 4th Nov 2007, 12:25
