hi,
refilled the colour cartridge on my lexmark 1150 all in one and now the colour refuses to print at all. tried cleaning the cartridge and the inside of the print carriage but still no colour. refilled black as well but its ok, have refilled before without a lot of drama......
any ideas.....anybody.....please i feel like dropping the whole thing out of the window. i have used lexmark ink etc but its just refusing to print have done nozzle clean about 20 times but only black comes out
thanks
marni
my problem is not the refilled cartridge as a new cartridge i tried will not print either, someone please help, i have important things to print NOW and i am going NUTS!!!!!!!
i found this on goolge
from this site: http://forums.computeractive.co.uk/thread.jsp?forum=14&thread=32415
Its easy enough to refill the cartridges prticularly the black ones, you dont even have to remove from printer, there is an air hole on the top just insert the needle through that, dont overfill, if you have allowed the nozzles to dry out then soak in a saucer of warm water, should work OK, better really to refill before running empty
Do Lexmark printers reject refilled ink cartridges?
By yoda313 in forum ComputerReplies: 14Last Post: 21st Oct 2012, 15:02 -
Ink cartridge cannot be reconized
By Teac23 in forum ComputerReplies: 2Last Post: 2nd Mar 2011, 12:04 -
Any idea what this cartridge is?
By zevious in forum Newbie / General discussionsReplies: 3Last Post: 9th Mar 2009, 14:33 -
Does the lexmark x4530 support borderless printing? - margin issue
By yoda313 in forum ComputerReplies: 0Last Post: 25th Jan 2009, 20:30 -
Online Inkjet cartridge source suggestions
By ranchhand in forum ComputerReplies: 6Last Post: 25th Sep 2007, 19:12
