Is it possible to ripp part of a dvd movie. I really don't want to ripp the whole movie and then take the scenes out that i don't want. Thanks
FInd out what chapter the section of the film is in and then most DVD ripping progs will allow you to select only that chapter (smartripper and DVD decrypter)...good luck.
mark -
I've never tried it but I would think that if you follow the item concerning vegas video it may be possible to use it to edit exactly the parts you want, as I said, never tried it and am also a newbie but it would be the first place I would try.
Hope it helps -
Just use tempeg mepeg tools to rip the part you want it the esay way to go really.
Is there really no application that can ripp/save this video ?
By harry88 in forum Video Streaming DownloadingReplies: 4Last Post: 5th Mar 2012, 12:05 -
BD ripp for edition in vegas -
By Klemc in forum Blu-ray RippingReplies: 10Last Post: 3rd Aug 2010, 23:48 -
Bluray ripp to lagarith 720x405 resize VirtualDub
By Klemc in forum Video ConversionReplies: 13Last Post: 3rd Aug 2010, 23:45 -
what is the fastest software to RIPP into H264 ?
By james_patageul in forum DVD RippingReplies: 8Last Post: 12th Apr 2010, 12:46 -
ADVICE needed plz! As of Feb 08, best format to ripp DVDs? TIA.
By carapalida in forum Newbie / General discussionsReplies: 3Last Post: 13th Feb 2008, 11:11
