I have been using TMPGE for months. I decided to give my p.c. a programme overhaul by installing Windows XP and the latest versions of Smart ripper, DVDtoAVI and TMPGE 2.01. After ripping and going through the DVDtoAVI process I start up the TMPGE programme and select video source for the d2v but all it comes up with now is “can not open, or unsupported”. Has anyone else had this problem after having installed Windows XP. I’m not sure if it's the XP or the ripper, dvdtoavi, tmpge. Any help would be most appreciated.
Cheers Voob
Did you forget to go into options of tmpgenc and check tmpgenc.vfp is registered to vfapi? Or made sure that in dvd2avi it is checked also? I have no problems with tmpgenc and XP.
I encoded several avi before, but then started having the same problem. No idea what happened. I downloaded the vfapi and no changed. I can't find the dvd2avi
thanks in advance
Certain d2v file causing problems with MeGUI Avisynth Script Creator.
By Simcut in forum Newbie / General discussionsReplies: 5Last Post: 30th Jul 2012, 17:57 -
What does this .d2v parse tell me?
By fatcharlie in forum Newbie / General discussionsReplies: 54Last Post: 10th Mar 2011, 18:13 -
MeGUI problems since using windows 7 - PLEASE HELP!!
By qwertym in forum DVD RippingReplies: 4Last Post: 28th Mar 2010, 21:54 -
Windows 7 problems
By SEK in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 15th Nov 2009, 17:33
