when i captured file from my camcorder picture is interlaced
DV camcorder? Yes, that would be interlaced.Originally Posted by rmb_ali
So what is the problem? -
You only want to dreinterlace if your final video is for viewing on your computer only as a standalone video file. I have Ulead Media Studio Pro , the capture component has a deinterlace video check box under the preferences section. Probably the same for Video Studio.
Well I don't know what else to suggest, Are you possibly using a preset that captures deinterlace video? Maybe a bad installation?
i have another problem with ulead videostudio , when i wana stop captur ,the tape don't stop and videostudio not response
I'd try to reinstall first, make sure if there's any updates at Ulead that you install them. Or use a different app.
Might want to also make sure you have windows up to date....
Output file is a mess - judder & interlaced....
By The.King in forum Video ConversionReplies: 6Last Post: 29th Jan 2011, 22:44 -
progressive input gives interlaced output...
By bennn in forum ffmpegX general discussionReplies: 4Last Post: 9th Dec 2010, 13:32 -
VirutaDUB Interlaced Output and Audio Errors.
By vodmare in forum Video ConversionReplies: 25Last Post: 16th Aug 2010, 07:42 -
encode interlaced material witth ffmepg to MPEG2 but get progressive output
By Massa in forum ffmpegX general discussionReplies: 9Last Post: 13th Jan 2009, 13:42 -
How (exactly) does my camcorder generate interlaced output?
By wayback in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 29th Jun 2007, 19:21
