Can You put 2 movies on a dvd-r using DVD Shrink 2.3, (I know there are newer versions but I need to be able to control the compression levels for the movies.) If it's possible to do so, could someone tell me how. Thanx.
Results 1 to 13 of 13
the site has guide using version 2.3 -
Yes you can. You use the "Re-Author" button. You simply drag and drop the 1st DVD from the right hand window to the left hand window. You then do the same for the 2nd DVD.
The right hand window will allow you to select your DVD/s from either your hard drive or DVD Rom etc. However, you will not be able to have menus if you do this and if both movies are big, you will need to compress to fit your blank DVD and may sacrifice video quality if there is a lot of compression.
The "Re-Author" utility is an excellent tool. You can even select the start and end point for each movie, thereby trimming out unwanted material. You can also select which audio format the DVD players should default to, whether to have captions or not etc....play around with it, it is dead easy to use and other than sacrificing any menus, it is excellent. -
my one question is why use 2.3 when 3.1 is available??
the original post is about v2.3 I wasn't meaning your link.
I dont see anything wrong with the latest build of dvdshrink personallyduh! the link i provided has a guide for 2.3 on putting 2 movies on one dvd disc! you may not have problems with the latest build of dvd shrink but others have.
The problem is when I open 2nd Dvd wheather on Hd or from Disc, re-author window closes & will olny show one disc or the other not both. None of the guides addressed this issue.
Hi Roswell Jedi. I have the same problem as you when trying to use Shrink 2.3. I use 3.0 Beta 5 for this purpose and it works a treat !!!!
I think you need to either have two DVD Drives or rip one to the HD for it to work. I know with 3.05B you open first movie, click reauthor, drag first tile across to reauthor window, go back to the first window and open second movie and repeat.
I resisted to upgrade from 3.05B to 3.17 for quite a while but now that I have upgraded I am most impressed by the extra features - writing directly to ISO is great IMO.If in doubt, Google it. -
I've downloaded 3.17, but now both movies are too big for the dvd-r. The first movie is at 46 percent & the 2nd is at 42 percent. Is there a way to lower custom ratio?
Originally Posted by Roswell Jedi
It sounds like the movies you are trying to put on might be too big/complex. For quality's sake you might be better off re-encoding because I think you are asking too much of the software. There's no reason why you can't ignore the disc size error and run the output through DVDShrink again, but quality is sure to be an issue.
What are the running times of the two movies ???If in doubt, Google it.
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 22:03 -
movies will not shrink small enough
By sugadaddy in forum DVD RippingReplies: 10Last Post: 14th Feb 2008, 21:51 -
What to do when DVD shrink does not shrink enough
By Firewire60 in forum Video ConversionReplies: 4Last Post: 23rd Sep 2007, 23:07 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 17:59 -
DVD wont shrink enough using DVD shrink?
By fazeshot in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2007, 21:31
