Hi, I have a problem with still images in Priemiere (also the Pinnacle SW).
I would like to create a project with still images (photos from digital camera). When I export the project to DVD (or DV tape) and I can see a jitter of light, white and shining places of the photos on the TV screen (PAL).
I try to use "Video options - Frame hold - Deinterlace" but the problem after exporting is still the same.
Either before you load the images into Premiere, or after you have set up the track, apply a small gaussian blur (0.02). This will soft the image enough to avoid the interlace without making it look too soft on screen.
I suggest applying it to the images in photoshop before loading them into Premiere or you will blow out your render times. Guassian blur can be slow to calculate in Premiere. -
OK, thank you very much. The time for rendering is not so important for me. Because I am new in Premiere can you tall me please, how can I do this "small gaussian blur (0.02)" in Premiere ? Something about it a read somewhere in czech forums but I canīt find it now.
OK, this is for premiere pro, but should be similar in previous versions.
1. find your clip on the timeline.
2. locate the gaussian blur video effect in the effects palette.
3. drag the effect onto the clip on the timeline
4. adjust the settings. premiere only allows adjustments to one decimal place, so set the blur to 0.1 in the vertical direction only
5. render and watch
depending on the amount of shimmer, you may not be able to get rid of all of it without making the clip too blurry to watch. Just find the best trade off -
Could colour correction perhaps fix this problem??
White is fine for your computer monitor, but not for the TV..
How about this, go to the titler, with the problem image in the backround..Use the colour picker, and pick the colour that gives you headaches. IF an exclamation mark appears above the colour, then you're using unsafe levels..
See if Premiere allow you to adjust levels, much like Photoshop does...
Good luck!!! -
Gunslider: I have applyed the effect on the clip but I canīt find dhe adjustment ? Can you help me again, place ? Do I have to use also the deinterlace check box ?
Hello,
Take a look in this one...
https://www.videohelp.com/forum/viewtopic.php?t=192278
Wood
My 2 problems with Adobe Premiere
By IT learner in forum EditingReplies: 2Last Post: 16th Sep 2011, 08:46 -
Premiere Cs3 Export problems
By owendude in forum EditingReplies: 3Last Post: 24th Jul 2009, 09:58 -
DVD to Sony Vegas synch / jitter problems
By Mike Toole in forum EditingReplies: 3Last Post: 19th Feb 2008, 23:15 -
Why Does One Mpg Jitter and One Doesn't? And Why The Jitter?
By abrogard in forum Video ConversionReplies: 10Last Post: 17th Nov 2007, 02:21 -
Playback problems in Premiere
By JustinBaker in forum EditingReplies: 4Last Post: 7th Nov 2007, 10:41
