How do I mix an ac3 audio track into an avi video? Thank You.
you have to use VirtualdubMod. under the streams menu, select stream list, and then add the audio track you want. make sure the video is set to 'direct stream copy' and then 'save as' to make you avi with sound.
Virtuadub 1.99 with plugin pack, unable to locate avc1
By Mark669 in forum EditingReplies: 21Last Post: 16th Dec 2010, 11:29 -
VirtuaDub Flags. FPS.
By vodmare in forum Newbie / General discussionsReplies: 1Last Post: 4th Aug 2010, 03:08 -
VirtuaDub Mp3 codec doesnt work (Windows 7) ?
By Chrushev in forum Video ConversionReplies: 4Last Post: 23rd Oct 2009, 03:08 -
My encoding codecs dont show up in virtuadub
By shadowofanubis6 in forum Newbie / General discussionsReplies: 6Last Post: 25th Feb 2009, 08:28 -
Virtuadub shows two different frame rates ?
By vodmare in forum Video ConversionReplies: 8Last Post: 12th May 2008, 19:47
