Hey everyone
Ive been using svcd2dvd for a while now no problems then about 2 weeks ago all the dvds i made stopped working in all my dvd players. they all say check tv format or wrong format. They wont even play in my playstation 2 anymore. My computer was acting a little funny so i reformatted it and started all over again and starting burning some dvd's and same problem. the only thing they'll play in is a cheap (and i mean cheap) sanyo dvd player. any idea why its doing this all of a sudden. i'm using the same media i was previously a 50 pack of memorex 4x dvd-r's. i tried the + R and some phillips and all say the same thing. Please help..
heres a log from my latest coaster i don't know what to look for if anything but here
"Starting SVCD2DVD: v1.51.2.0
Begin time: 9:39:55 PM
******** Ripping BIN images to get mpegs (VCDGear )
VCDGear 1.76 final build 031225 coded by Dracore (vcdgear@hotmail.com)
Testing and quality control by MACKerMD
Language: English
Version: 3.50 - Jan. 1, 2003
Translation by: Dracore
processing method :: (bin2mpg)
.bin src(In) -> C:\Documents and Settings\Lucky Bagota\My Documents\Working Folder\vcd_tdatpts1.bin
.mpg dest(Out) -> C:\Documents and Settings\Lucky Bagota\My Documents\Working Folder\vcd_tdatpts1.mpg
[vcd_tdatpts1.bin] Detected sector size: 2352
# 0%
#searching...
Track 1: 821829148 bytes [05:45:72]
#searching...
1 track(s).
Setting read size to: 2352
Setting write size to: 2324
# Track 1 -> writing...
# OK!
Language: English
.bin src(In) -> C:\Documents and Settings\Lucky Bagota\My Documents\Working Folder\vcd_tdatpts2.bin
.mpg dest(Out) -> C:\Documents and Settings\Lucky Bagota\My Documents\Working Folder\vcd_tdatpts2.mpg
[vcd_tdatpts2.bin] Detected sector size: 2352
# 0%
#searching...
Track 1: 792133076 bytes [02:55:44]
#searching...
1 track(s).
# OK!
(Total size: 1559MB, Duration: 00:01:41, Rate(MB/Min): 921.86)
Analysing File: C:\Documents and Settings\Lucky Bagota\My Documents\Working Folder\vcd_tdatpts1.mpg
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'next_I_offset ': [00:00.3a]
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'previous_I_offset': [00:00.3a]
++ WARN: packet length beyond buffer (pos = 20 + size = 2304 > buflen = 452) -- stream may be truncated or packet length > 2324 bytes!
++ WARN: bad packet at packet #451 (stream byte offset 1048124) -- remaining 452 bytes of stream will be ignored
Analysing File: C:\Documents and Settings\Lucky Bagota\My Documents\Working Folder\vcd_tdatpts2.mpg
++ WARN: unknown user data tag id 0x28 encountered
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'forward_I_offset ': [00:06.3d]
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'next_I_offset ': [00:00.4a]
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'previous_I_offset': [00:00.4a]
-->Processing 2 mpeg files
############### New MPEG File ###############
Type: SVCD
Horizontal Res: 480
Standard: PAL
Audio SampleRate: 44100
******** Demultipexing original mpg file
(Total size: 783MB, Duration: 00:01:16, Rate(MB/Min): 616.00)
******** Resampling audio from 44.1 KHz to 48 KHz
MPEG Audio Decoder 0.15.0 (beta) - Copyright (C) 2000-2003 Robert Leslie et al.
132054 frames decoded (0:57:29.5), -0.0 dB peak amplitude, 0 clipped samples
132054 frames decoded (0:57:29.5), -0.1 dB peak amplitude, 0 clipped samples
(Total size: 92MB, Duration: 00:03:06, Rate(MB/Min): 29.64)
******** Trimming start of video ES
- Nothing to do.
******** Multipexing elementry streams
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
INFO: [mplex] File C:\Documents and Settings\Lucky Bagota\My Documents\Working Folder\vcd_tdatpts1_DVD.mpv looks like an MPEG Video stream.
INFO: [mplex] File C:\Documents and Settings\Lucky Bagota\My Documents\Working Folder\vcd_tdatpts1_CH1_DVD.mpa looks like an MPEG Audio stream.
INFO: [mplex] File C:\Documents and Settings\Lucky Bagota\My Documents\Working Folder\vcd_tdatpts1_CH2_DVD.mpa looks like an MPEG Audio stream.
INFO: [mplex] Video stream 0: profile 8 selected - ignoring non-standard options!
INFO: [mplex] Found 2 audio streams and 1 video streams
INFO: [mplex] Selecting dvdauthor DVD output profile
INFO: [mplex] Multiplexing video program stream!
INFO: [mplex] Scanning for header info: Video stream e0 (C:\Documents and Settings\Lucky Bagota\My Documents\Working Folder\vcd_tdatpts1_DVD.mpv)
INFO: [mplex] VIDEO STREAM: e0
INFO: [mplex] Frame width : 480
INFO: [mplex] Frame height : 576
INFO: [mplex] Aspect ratio : 4:3 display
INFO: [mplex] Picture rate : 25.000 frames/sec
INFO: [mplex] Bit rate : 2556000 bits/sec
INFO: [mplex] Vbv buffer size : 131072 bytes
INFO: [mplex] CSPF : 0
INFO: [mplex] Scanning for header info: Audio stream c0 (C:\Documents and Settings\Lucky Bagota\My Documents\Working Folder\vcd_tdatpts1_CH1_DVD.mpa)
INFO: [mplex] MPEG AUDIO STREAM: c0
INFO: [mplex] Audio version : 1.0
INFO: [mplex] Layer : 2
INFO: [mplex] CRC checksums : no
INFO: [mplex] Bit rate : 28672 bytes/sec (224 kbit/sec)
INFO: [mplex] Frequency : 48000 Hz
INFO: [mplex] Mode : 0 stereo
INFO: [mplex] Mode extension : 0
INFO: [mplex] Copyright bit : 0 no copyright
INFO: [mplex] Original/Copy : 1 original
INFO: [mplex] Emphasis : 0 none
INFO: [mplex] Scanning for header info: Audio stream c1 (C:\Documents and Settings\Lucky Bagota\My Documents\Working Folder\vcd_tdatpts1_CH2_DVD.mpa)
INFO: [mplex] MPEG AUDIO STREAM: c1
INFO: [mplex] SYSTEMS/PROGRAM stream:
INFO: [mplex] rough-guess multiplexed stream data rate : 3061200
INFO: [mplex] target data-rate specified : 10080000
INFO: [mplex] Setting specified specified data rate: 10080000
INFO: [mplex] Run-in Sectors = 90 Video delay = 13165 Audio delay = 13165
INFO: [mplex] New sequence commences...
INFO: [mplex] Video e0: buf= 237568 frame=000000 sector=00000000
INFO: [mplex] Audio c0: buf= 4096 frame=000000 sector=00000000
INFO: [mplex] Audio c1: buf= 4096 frame=000000 sector=00000000
INFO: [mplex] Scanned to end AU 85982
INFO: [mplex] STREAM e0 completed @ frame 85982.
++ WARN: [mplex] Discarding incomplete final frame MPEG audio stream c0!
++ WARN: [mplex] Discarding incomplete final frame MPEG audio stream c1!
INFO: [mplex] STREAM c0 completed @ frame 143730.
INFO: [mplex] STREAM c1 completed @ frame 143730.
INFO: [mplex] Multiplex completion at SCR=310461732.
INFO: [mplex] Video e0: buf= 237568 frame=085982 sector=00354337
INFO: [mplex] Audio c0: buf= 1408 frame=143730 sector=00047816
INFO: [mplex] Audio c1: buf= 1408 frame=143730 sector=00047816
INFO: [mplex] VIDEO_STATISTICS: e0
INFO: [mplex] Video Stream length: 712715134 bytes
INFO: [mplex] Sequence headers: 4794
INFO: [mplex] Sequence ends : 1
INFO: [mplex] No. Pictures : 85982
INFO: [mplex] No. Groups : 4794
INFO: [mplex] No. I Frames : 4794 avg. size 26428 bytes
INFO: [mplex] No. P Frames : 23904 avg. size 12066 bytes
INFO: [mplex] No. B Frames : 57285 avg. size 5194 bytes
INFO: [mplex] Average bit-rate : 1657600 bits/sec
INFO: [mplex] Peak bit-rate : 2424800 bits/sec
INFO: [mplex] BUFFERING min 15 Buf max 134306
INFO: [mplex] AUDIO_STATISTICS: c0
INFO: [mplex] Audio stream length 96587236 bytes.
INFO: [mplex] Syncwords : 143732
INFO: [mplex] Frames : 143732 padded
INFO: [mplex] Frames : 0 unpadded
INFO: [mplex] BUFFERING min 15 Buf max 683
INFO: [mplex] AUDIO_STATISTICS: c1
INFO: [mplex] MUX STATUS: no under-runs detected.
(Total size: 888MB, Duration: 00:04:43, Rate(MB/Min): 187.93)
Analysing File: C:\Documents and Settings\Lucky Bagota\My Documents\Working Folder\vcd_tdatpts1_DVD.mpg
++ WARN: mpeg stream will be padded on the fly -- hope that's ok for you!
++ WARN: autopadding requires to insert additional 141036 zero bytes into MPEG stream (due to 511 unaligned packets of 512 total)
Type: SVCD
Horizontal Res: 480
Standard: PAL
(Total size: 755MB, Duration: 00:01:27, Rate(MB/Min): 517.81)
127044 frames decoded (0:55:18.7), -0.0 dB peak amplitude, 0 clipped samples
127044 frames decoded (0:55:18.7), -0.1 dB peak amplitude, 0 clipped samples
(Total size: 88MB, Duration: 00:03:00, Rate(MB/Min): 29.27)
- Nothing to do.
INFO: [mplex] File C:\Documents and Settings\Lucky Bagota\My Documents\Working Folder\vcd_tdatpts2_DVD.mpv looks like an MPEG Video stream.
INFO: [mplex] File C:\Documents and Settings\Lucky Bagota\My Documents\Working Folder\vcd_tdatpts2_CH1_DVD.mpa looks like an MPEG Audio stream.
INFO: [mplex] File C:\Documents and Settings\Lucky Bagota\My Documents\Working Folder\vcd_tdatpts2_CH2_DVD.mpa looks like an MPEG Audio stream.
INFO: [mplex] Scanning for header info: Video stream e0 (C:\Documents and Settings\Lucky Bagota\My Documents\Working Folder\vcd_tdatpts2_DVD.mpv)
INFO: [mplex] Scanning for header info: Audio stream c0 (C:\Documents and Settings\Lucky Bagota\My Documents\Working Folder\vcd_tdatpts2_CH1_DVD.mpa)
INFO: [mplex] Scanning for header info: Audio stream c1 (C:\Documents and Settings\Lucky Bagota\My Documents\Working Folder\vcd_tdatpts2_CH2_DVD.mpa)
INFO: [mplex] Scanned to end AU 82965
INFO: [mplex] STREAM e0 completed @ frame 82965.
INFO: [mplex] STREAM c0 completed @ frame 138277.
INFO: [mplex] STREAM c1 completed @ frame 138277.
INFO: [mplex] Multiplex completion at SCR=298683245.
INFO: [mplex] Video e0: buf= 222639 frame=082965 sector=00341653
INFO: [mplex] Audio c0: buf= 1408 frame=138277 sector=00046002
INFO: [mplex] Audio c1: buf= 1408 frame=138277 sector=00046002
INFO: [mplex] Video Stream length: 687138539 bytes
INFO: [mplex] Sequence headers: 4620
INFO: [mplex] No. Pictures : 82965
INFO: [mplex] No. Groups : 4620
INFO: [mplex] No. I Frames : 4620 avg. size 26396 bytes
INFO: [mplex] No. P Frames : 23053 avg. size 12001 bytes
INFO: [mplex] No. B Frames : 55293 avg. size 5218 bytes
INFO: [mplex] Average bit-rate : 1656400 bits/sec
INFO: [mplex] Peak bit-rate : 2371200 bits/sec
INFO: [mplex] BUFFERING min 16 Buf max 135228
INFO: [mplex] Audio stream length 92922820 bytes.
INFO: [mplex] Syncwords : 138279
INFO: [mplex] Frames : 138279 padded
(Total size: 856MB, Duration: 00:04:34, Rate(MB/Min): 187.32)
Analysing File: C:\Documents and Settings\Lucky Bagota\My Documents\Working Folder\vcd_tdatpts2_DVD.mpg
******** Creating DVD Folders...
Creating VTS #1
SVCD2DVD: DVDfolders
Generating DVD folders please wait....
-->: DVDFolders creating VTS
-->: VTS 01
STAT: Processing C:\Program Files\BadgerSoft\SVCD2DVD\dummymenuNTSC.mpg...
STAT: Processing C:\Documents and Settings\Lucky Bagota\My Documents\Working Folder\vcd_tdatpts1_DVD.mpg...
!!!: GOP is not closed on cell boundary (may be non seamless)
STAT: Processing C:\Documents and Settings\Lucky Bagota\My Documents\Working Folder\vcd_tdatpts2_DVD.mpg...
ADDING PRE COMMAND!
ADDING PRE COMMAND!
ADDING PRE COMMAND!
ADDING PRE COMMAND!
!!!: Audio channel 1 gap is negative (-897120) on title 1 chapter 2
!!!: Audio channel 2 gap is negative (-897120) on title 1 chapter 2
(Total size: 1744MB, Duration: 00:02:48, Rate(MB/Min): 622.86)
-->: DVDFolders creating table of contents
scanning C:\Documents and Settings\Lucky Bagota\My Documents\Working Folder\Ready To Burn\VIDEO_TS/VTS_01_0.IFO
-->: Creating menu for TOC
STAT: Processing C:\Documents and Settings\Lucky Bagota\Local Settings\Application Data\Badgersoft\DVD MenuMaker\1.0.1605.17877\1a8822e6-b5d3-4f5d-ba15-3434c01154b9\menu.mpg...
============ Complete ============
============ Duration: 00:22:42" -
I notice this has two audio channels.... Can you send me a sample. Use the make sample tool from the menu. Make the sample as big as your upload bandwidth allows.
Send it to ftp://svcd2dvd:Upload@ftp.svcd2dvdmpg.com:7676/ (make a folder) then email me to tell me its there. I will investigate.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Im havin tha same problems.....ive been usin this program for almost a year & i never had problems.....all of a sudden it wont play on any of my dvd players ( it use to play on all my dvd players ) & the only thing that will read them is my xbox....i havent changed anything that i have been doin from when they did work till now....i dont know whats wrong....i think its time for a new program or something...lol
DV won't play correctly anymore.
By xtremeD63 in forum Software PlayingReplies: 52Last Post: 9th Apr 2011, 14:08 -
Windows Media Player Won't Play DVDs Anymore
By Card Shark in forum Newbie / General discussionsReplies: 3Last Post: 14th Feb 2010, 19:04 -
DV video clip won't play anymore
By cajustse in forum Newbie / General discussionsReplies: 3Last Post: 11th Jun 2009, 15:57 -
My player won't play burned discs anymore.
By uNderdog_101 in forum DVD & Blu-ray RecordersReplies: 14Last Post: 30th Dec 2007, 17:44 -
Help! My Dvd Player Won't Mp3's Anymore
By Just8 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 2nd Jul 2007, 00:08
