hi,
i was wondering how i could add "masking" on faces on my own movies.
for instance, i go to the beach and a wave take off my swimsuit...
I always wondered how tv shows like gag-videos and stuff...could encode a moving object.
I hope this is the right place for posting this question...
thx for answering,
If your source is DV, you should check into Virtualdub filters. They would probably do what you want. There is a logo and logoway filters that may do it. You would have to adjust the movement of the filter for the proper 'blur' effect. Check for 'virtualdub filters' on the web.
If you want to blur out certain parts of a moving image, you need to look at software that supports masking and tracking in some form. Many editing programs, such as Vegas or Premiere can do this, however it is a manual process. You would have to track the parts you wish to blur our by hand using keyframes to move you mask around.
Compositing programs such as Combustion, After Effects or Fusion can do some (or all) of the tracking for you, making life easier. Of course, these generally are not cheap programs. -
thx guys for helping me!
guns1inger wich best easier prg suits my need in my case?
will Vegas for instance make the same job than premiere with blur effect? -
No offence, but if you have to ask the question, the I suspect both will be difficult for you. Both are complex beasts for people not used to editing in higher end software. Both work in different ways. You really need to download the demos and have a play to see which one suits you best.
My preference is Vegas, although for this I would probably use after effects -
Originally Posted by 3Dzigner
http://www.wrigleyvideo.com/videotutorial/tutdes_blurface.htm
cheers -
and if you decide to try Vegas, here is a tutorial to do the "hidden identity" masking.
- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light"
Removing moving object from a video
By Lucky Starr in forum EditingReplies: 4Last Post: 31st Mar 2012, 15:39 -
Hiding a moving object
By akkers in forum EditingReplies: 0Last Post: 29th Nov 2011, 05:59 -
HELP! Need to know about tracking a moving object in a video
By RPH2515 in forum Newbie / General discussionsReplies: 7Last Post: 22nd Aug 2010, 08:02 -
hide moving object in VDub??
By 3thman in forum EditingReplies: 2Last Post: 16th Oct 2009, 08:53 -
Adding object(moving hand ) to a video file
By dnmnbg in forum Newbie / General discussionsReplies: 2Last Post: 18th Jun 2009, 04:25
