Hi,
I have been trying to search on tutorial on how to add subtitle on your DVD.
The one i found is only from backing up from a DVD movie -which has all the bits for the subtitle and alter or add another subtitle. (this is not what i want)
What i need is adding subtitle to our OWN movie (From handy cam or AVI or MPEG2 files).
What software do i need?
What's the process on dong this?
If anyone has the info and able to help me. I would really appreciate.
Arda
You are not going to get much help with that enigmatic topic title. You might want to rename it.
please use a subject that describes your topic. i changed it for you.
Make the subs with subtitle workshop and then import them with dvdauthorgui or dvd-lab pro or ulead dvd workshop and make a dvd(they all support switchable subtitles). Done.
How to add your own subtitle to DVD (keep menu, multi-pgc)
By bluedha in forum User guidesReplies: 339Last Post: 10th Oct 2013, 21:11 -
Add new subtitle to an existing DVD with warning screens, intros & trailers
By Charmer in forum Authoring (DVD)Replies: 7Last Post: 11th Aug 2011, 18:59 -
How can I add a subtitle into ts file in DVB subtitle format
By elmc in forum SubtitleReplies: 1Last Post: 20th Jul 2008, 15:37 -
How to insert *.srt subtitle and add button to DVD menu?
By goodvd in forum SubtitleReplies: 1Last Post: 17th May 2008, 22:04 -
i add subtitle to a dvd and the coulor after reauthor is black!!!
By siopilos in forum SubtitleReplies: 1Last Post: 18th Jul 2007, 22:19
