I have 4 seaprate xvid AVIs that play fine in quicktime. The movies total only about an hour, but the file size is close to 1gig; I'm trying to encode them to divx to fit on one CD.
I copy and pasted all the clips into one movie in Quicktime pro, then saved it as a self contained movie.
The problem is the encoding seems to keep finishing at around 53 minutes, and the audio is not getting encoded at all. Strange, because so errors are being reported, but obviously some must be occuring. Perhaps someone can make sense of the output:
I get a lot of those 'vop not coded'; I left most of them outCode:Encoding started on Fri Jun 25 13:46:46 EDT 2004 MEncoder dev-CVS-040614-23:18-3.3 (C) 2000-2004 MPlayer Team AltiVec found CPU: PowerPC Reading /Users/myname/.mplayer/codecs.conf: Reading /usr/local/etc/mplayer/codecs.conf: Using built-in default codecs.conf. Font /usr/local/share/mplayer/font/font.desc loaded successfully! (206 chars) success: format: 0 data: 0x0 - 0x3E4F94FB QuickTime/MOV file format detected. -------------- MOV track #0: 12943 chunks, 77586 samples Image size: 512 x 384 (24 bpp) Display size: 512 x 384 Fourcc: DIVX Codec: '' -------------- MOV track #1: 19088 chunks, 109793 samples Audio bits: 16 chans: 2 rate: 44100 Audio extra header: len=80 fcc=0x77617665 MOV: Found unknown audio atom Ä>Fourcc: 3pm. -------------- MOV track #2: 5383 chunks, 32252 samples MOV: selected audio stream (0) does not exists Image size: 512 x 384 (24 bpp) Display size: 512 x 384 Fourcc: DIVX Codec: '' -------------- MOV: longest streams: A: #1 (109793 samples) V: #0 (77586 samples) [V] filefmt:7 fourcc:0x44495658 size:512x384 fps:23.98 ftime:=0.0417 Opening video filter: [expand osd=1] Expand: -1 x -1, -1 ; -1 (-1=autodetect) osd: 1 Opening video filter: [scale w=512 h=384] ========================================================================== Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family Selected video codec: [ffodivx] vfm:ffmpeg (FFmpeg MPEG-4) ========================================================================== Writing AVI header... ODML: Aspect information not (yet?) available or unspecified, not writing vprp header. VDec: vo config request - 512 x 384 (preferred csp: Planar YV12) VDec: using Planar YV12 as output csp (no 0) Movie-Aspect is 1.33:1 - prescaling to correct movie aspect. SwScaler: using unscaled Planar YV12 -> Planar YV12 special converter videocodec: libavcodec (512x384 fourcc=58564944 [XVID]) vop not coded 1 duplicate frame(s)! vop not coded 1 duplicate frame(s)! vop not coded 1 duplicate frame(s)! vop not coded ... Writing AVI index... Fixing AVI header... ODML: vprp aspect is 4:3. Video stream: 1045.578 kbit/s (130697 bps) size: 422863815 bytes 3235.444 secs 77586 frames Encoding completed on Fri Jun 25 14:50:04 EDT 2004
TIA for any help
It sounds like you have 4 xvids, you're combining them in QTPro, saving as a new mov file, and then encoding the mov to divx with ffmpegx?
I would suggest trying to encode each xvid seperately, and then joining them up afterwards (just copy n paste in QT pro). Skip the whole mov step.
PS Merely going from xvid to divx isn't going to change your filesize by any significant amount, unless you also reduce bitrates (and quality)
Divx multipass encoding
By silverwolf0 in forum Newbie / General discussionsReplies: 9Last Post: 7th Jun 2009, 12:31 -
Divx Author 1.5 Re-encoding standard divX files
By ejai in forum Authoring (DVD)Replies: 2Last Post: 9th Jul 2008, 19:28 -
DivX Encoding Problems
By ftshark in forum DVD RippingReplies: 3Last Post: 7th Mar 2008, 11:30 -
DVD to DivX encoding?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2008, 12:33 -
Cut Divx without Re-encoding
By kman22 in forum EditingReplies: 8Last Post: 26th Nov 2007, 18:39
