I can't play *.avi files anymore???![]()
It have always worked so????
Windows mediaplayer or Winamp crash, and so does the explorer!
Am I missing a codec or ???
TIA.
Results 1 to 13 of 13
Have you tried removing the programs that crash and re-installing?
Nah not really, because I don't think you can uninstall explorer.
I forgot to say that VirtualDub can play *.avi files? -
You could try a different player.
Bsplayer is really good and so is vlc media player. -
You don't get crashes due to missing codecs (unless an existing but incompatible codec claims to be the right one), you get an error message instead.Originally Posted by John_do
I've had problems like this in the past due to installing a buggy AVI codec on my PC. When Windows AVI support is activated it does some kind of check (I don't know the details) of all the installed codecs. Once it reaches the buggy codec, it crashes.
Have you installed some kind of codec pack recently? Or any kind of video related software that might have installed some codecs?
If so, and if you are using XP then hopefully you created a restore point just before it, in which case you can restore to that point. Otherwise you may have to uninstall or disable codecs manually until you find the culprit. -
And I forgot to say why...Originally Posted by John_do
The Windows OS has built in support for reading AVI files, but not every app uses it, partly because the interface is rather limited, and partly to avoid problems like this. Media Player (naturally) uses the OS, and so will many other apps. VirtualDUB I believe does not, it uses its own AVI processing code, and hence is not susceptible. -
I believe VirtualDUB only uses VFW for video capture. For reading already existing AVIs it has its own AVI parser - see AVIReadHandler.cpp in the VDub source code.Originally Posted by junkmalle
If a bad WDM filter is the cause, what to do about it? And what is a WDM filter?
Yeah, i know, but the pity is that i make use of SubSync for subtitling and that program uses Windows Mediaplayer! So i can't use SubSync anyfurther!Originally Posted by bazooka
Thanks mpack, I took a quick look at the source and you're right about VirtualDub's AVI file parsing. So that could be a source of problems with other programs.Originally Posted by mpack
WDM is Windows Device Manager. Try playing the file with Windows Media Player 6.4 -- it's included with Windows XP in c:\program files\windows media player\mplayer2.exe. If you can open the file with that you can use File -> Properties -> Advanced to get a list of all the codecs and filters that are used.Originally Posted by bighousie
DV won't play correctly anymore.
By xtremeD63 in forum Software PlayingReplies: 52Last Post: 9th Apr 2011, 14:08 -
DV video clip won't play anymore
By cajustse in forum Newbie / General discussionsReplies: 3Last Post: 11th Jun 2009, 15:57 -
WMP 11 XP avi wont play anymore
By axlefoley in forum Newbie / General discussionsReplies: 6Last Post: 28th Feb 2008, 02:39 -
My player won't play burned discs anymore.
By uNderdog_101 in forum DVD & Blu-ray RecordersReplies: 14Last Post: 30th Dec 2007, 17:44 -
DVD player does not play sound anymore
By M_W in forum AudioReplies: 4Last Post: 9th Sep 2007, 05:20
