  1. Hi
    Iam trying convert a dvd to svcd using DVD2SVCD but after its video encoding when BBMpeg starts after a while it says "unable to Output file"
    This is the log
    WNASPI32.DLL 4.71.1.0
    - 6/24/2004 12:07:14 AM
    - DVD to SVCD Conversion
    - DVD2SVCD ver. 1.2.2 build 1
    Initializing
    - C:\Pirates Of The Caribbean\VTS_01_0.IFO
    - C:\Pirates Of The Caribbean\VTS_01_1.vob
    - C:\Pirates Of The Caribbean\VTS_01_2.vob
    - C:\Pirates Of The Caribbean\VTS_01_3.vob
    - C:\Pirates Of The Caribbean\VTS_01_4.vob
    - C:\Pirates Of The Caribbean\VTS_01_5.vob
    - C:\Pirates Of The Caribbean\VTS_01_6.vob
    - C:\Pirates Of The Caribbean\VTS_01_7.vob
    Initializing finished.
    - 6/24/2004 12:07:18 AM
    - Analyzing subtitles
    Subtitle found: StreamID: 0x21 Language: English
    Subtitle found: StreamID: 0x20 Language: English
    Executing subtitle selection/verification.
    Subtitle selection/verification accepted.
    1 subtitle streams selected.
    Saving Subtitles ini file
    - 6/24/2004 12:07:32 AM
    - DVD2AVI
    Creating DVD2AVI INI file:
    - E:\Program Files\DVD2SVCD\DVD2AVI\DVD2AVI.INI
    Variable settings:
    iDCT_Algorithm: 32-bit SSE MMX
    Executing DVD2AVI.
    Executing DVD2AVI. Commandline:
    "E:\Program Files\DVD2SVCD\DVD2AVI\DVD2AVI.exe" -CS=2 -YR=1 -OM=0 -EXIT -OF=[E:\Generation\DVD2AVI_Project_file] -IF=[C:\Pirates Of The Caribbean\VTS_01_1.vob,C:\Pirates Of The Caribbean\VTS_01_2.vob,C:\Pirates Of The Caribbean\VTS_01_3.vob,C:\Pirates Of The Caribbean\VTS_01_4.vob,C:\Pirates Of The Caribbean\VTS_01_5.vob,C:\Pirates Of The Caribbean\VTS_01_6.vob,C:\Pirates Of The Caribbean\VTS_01_7.vob]
    Framerate: 25000
    DVD2AVI processing done.
    - 6/24/2004 12:37:09 AM
    - Free on drive E: 3070.28 mb
    - Extracting the subtitles.
    Subtitle extraction finished. Extracted these subtitles:
    SVCD Stream no: 1 Language: English Num. of subs: 1239
    Saving Subtitle Timecodes.
    Permanent subtitles.
    - 6/24/2004 1:15:47 AM
    - Free on drive E: 3003.06 mb
    - AUDIO Extraction
    Found AC3 stream id: 0x80
    Filename: E:\Generation\Extracted_audio_1.ac3
    Audio1 delay: 0 ms
    Audio extraction finished.
    Encoding Audio. Filename: E:\Generation\Extracted_audio_1.ac3
    Executing BeSweet. Commandline:
    "E:\Program Files\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "E:\Generation\Extracted_audio_1.ac3" -output "E:\GENERA~1\Encoded_audio_1.mp2" -logfile "E:\GENERA~1\Encoded_audio_1.log" ) -azid( -L -3db -C 0db -S 0db -c normal -s surround -g max ) -2lame( -e -b 224 -m s )
    Audio conversion of E:\Generation\Extracted_audio_1.ac3 finished.
    Audio conversion finished.
    - 6/24/2004 2:40:22 AM
    - Free on drive E: 2335.14 mb
    - Video Encoding using TMPGEnc
    - Encoding E:\Generation\AviSynth_Script_file.avs
    StreamSectors: 2314613364
    AudioSectors: 234103492
    VideoPAPO: 32228208
    ScanOffsetBytes: 185384
    SeqAligningBytes: 11782170
    DVDBytes: 0
    VideoEndHeader: 12
    SubtitleSectors: 0
    EmptySectors: 238.00
    PictureSectors: 0.00
    PureMPEGStream: 2036314097.80
    Seconds: 8249.28
    CalcMPEGStream: 2036314097.80
    Frames: 205982
    CDSize: 740.00
    Number of CDs: 3
    Cut point 736.00
    Max. Bitrate: 2530
    Avg. Bitrate: 1974.78
    Min. Bitrate: 300
    Executing TMPGEnc. Commandline:
    "E:\Program Files\Eazy VCD\TMPGEnc\TMPGEnc.exe" "E:\Generation\TMPGEnc_Project_file.tpr" /Encode /Close
    Video Encoding finished.
    - 6/25/2004 6:49:30 PM
    - Free on drive E: 1127.08 mb
    - Converting Pictures from ES to PS
    Saving bbMPEG settings: E:\Program Files\DVD2SVCD\bbMPEG\default.ini
    - 6/25/2004 6:49:34 PM
    - Free on drive E: 1127.06 mb
    - 6/25/2004 6:49:37 PM
    - 6/25/2004 6:49:40 PM
    - Multiplexing and cutting
    Offset in Seconds: 1
    Executing bbMPEG.
    Variable Settings:
    Movie offset: 1 seconds
    Cut point: 736 mb
    Executing RunbbMPEG. Commandline:
    "E:\Program Files\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "E:\Generation\bbMPEG_Muxed_File.mpg"
    Length of E:\Generation\bbMPEG_Muxed_File00.mpg
    2730 Seconds
    Offset in Seconds: 2731
    Executing bbMPEG.
    Variable Settings:
    Cut point: 736 mb
    - 6/25/2004 7:45:58 PM
    Initializing
    - 6/25/2004 7:46:09 PM
    - Free on drive E: 26.23 mb
    - Crash Recovery
    - Restarting from: Muxing and Cutting
    - 6/25/2004 7:46:13 PM
    - Free on drive E: 38.39 mb
    - 6/25/2004 7:46:16 PM
    - Free on drive E: 851.42 mb
    - 6/25/2004 7:46:19 PM
    - 6/25/2004 7:46:22 PM
    Executing bbMPEG.
    Variable Settings:
    Cut point: 736 mb
    "E:\Program Files\DVD2SVCD\[removeme]bbMPEG[removeme]\RunbbMPEG.exe" "E:\Generation\bbMPEG_Muxed_File.mpg"
    2730 Seconds
    Executing [removeme]bbMPEG[removeme].
    Variable Settings:
    Cut point: 736 mb
    "E:\Program Files\[removeme]DVD2SVCD[removeme]\[removeme]bbMPEG[removeme]\RunbbMPEG.exe" "E:\Generation\bbMPEG_Muxed_File.mpg"
  2. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    something's not right:
    2730 Seconds
    Executing bbMPEG.
    Variable Settings:
    Cut point: 736 mb
    you can't use [ or ] in a command line path. the mpeg has been encoded, can't you do the cutting manually?
  3. Will i drop the quality if i do it manually.
  4. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    no, the encoding has been done. cutting the files manually doesn't affect the files.
  5. Why not to try other software like Xilisoft DVD Ripper?
    I think it does very well.
