mave a vcd mpeg-1 file that when played the video will freeze half way through playing the video, whilst the audio will keep playing just fine. I know I can use fast foward to skip the corrupt section and continue to watch, but does anybody know if there is any software availavble to fix the corrupt sections of the mpg files? All help appreciated.
You say you made it, from an avi. Check the avi for bad frames before you convert to mpeg. Guides for this can be located on the left.
I am having the same problem that the original poster is. I converted a series of AVIs to SVCD standard with MC and then made an SVCD with Nero. Several of the clips froze near the end, but the audio continued to play...what up?
"Bit Error" when playing AVIs on set top box - video freezes
By MLS in forum Newbie / General discussionsReplies: 1Last Post: 15th Jun 2011, 14:26 -
How do I: Record Video, Audio from MIC, AND Audio playing from speakers?
By miimaster2 in forum Newbie / General discussionsReplies: 8Last Post: 11th Feb 2011, 20:51 -
Video freezes, audio continues in Nero
By lj01 in forum EditingReplies: 2Last Post: 7th Apr 2008, 10:58 -
MPEG playing problems
By Dave Knowles in forum Software PlayingReplies: 5Last Post: 14th Oct 2007, 07:31 -
Convert divx vbr to cbr audio - video freezes (possible reason & soluti
By lingyi in forum AudioReplies: 0Last Post: 4th Oct 2007, 15:51
