I am trying to use dvdremake to fix the menus on Snatch. It has the fullscreen and widescreen formats on the same disc, and I am trying to get rid of the fullscreen while keeping the rest of the dvd working smoothly. I have tried playing around in the "simple" mode of DVDremake, but I cant get it to work right. Is there something that explains what everything means in the advanced mode? PGC, R[#], pre-commands, post-commands, I have no idea, and I can't find anything out there to explain it to me. Any help would be appreciated!
i would also like to see a guide on the meanings of everything. but i have only used it so far to delete or replace un wanted material. i do belive there is a guide floating around on here that will help you with what you are trying to do thoiugh. i say have a search in the forums and also try looking at dvdremake's website as there are a few guides on there for stuff like what you are trying to do.
cheers -
I finally found something useful, and it looks like its going to be a bitch to figure all this stuff out!!!!
http://www.dvd-replica.com/DVD/vmcommands.php
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 12:21 -
DVDremake Pro button problem
By Yaro in forum EditingReplies: 2Last Post: 16th Aug 2009, 16:54 -
Advantages of ripping in File mode over ISO mode...
By hiimbored in forum DVD RippingReplies: 9Last Post: 5th Jun 2008, 15:27 -
DVDRemake don't work?????????
By bens dad in forum Newbie / General discussionsReplies: 7Last Post: 4th Jan 2008, 12:18 -
DVDRemake Backup folder is not Playble
By src2206 in forum DVD RippingReplies: 2Last Post: 2nd Dec 2007, 13:03
