Are there any dvd recorder (stand alone) that can edit out commercials. Not hard drive recorders or ram drives. Thanks. -garman
You can do this with the Philips / Magnavox recorders and more easily on the Pioneer 220 / 320 units, however they do it in DVD-VR format. This means that if you want to play the disk in another unit, you will need to buy a Panasonic or Pioneer (maybe others) stand alone players which are "RW Compatible"
TJDLDW 5001, Nov 2003. Pioneer DVR-220-s, May 2004. Haup PVR-250 (2) Ver. 15 + 16. Slowpoke P4 1.8Ghz, 500 gig . Dish DVR-510 - 100 hrs. DirecTV RCA. DLP HD HT Projector at 170 Inches Diag. Tivo Gen. 1 with 180 hours -
Yes.
Cyberhome CH-DVR 1500 & 2500
Make chapters of the adverts, then "Hide" them.
When done, make the disk "Compatible" to play the dvd+r/rw on a DVD player.
If your player won't play it, than ISO-copy it onto a dvd-r. -
I suggest against any DVD+RW editing (tendancy to corrupt IFOs).
If you want to edit, go for DVD-RAM format.Want my help? Ask here! (not via PM!)
Well, as this post clearly indicated, no DVD-RAM. If you want simple editing features which DON"T require a PC or special format player, go for the Philips / Magnavox.
Cyberhome has some nice features, but I just can't get past the problems which have been reported with this unit...
I usually divide the title(one at the beginning and one at the end of the piece you DONT want)...then delete that title from the RW on my Philips 985. Once I have all of them technically gone from my disc then I take it to the computer. I've only had problems with "deleted" titles showing back up on regular "R" discs once they hit the computer.....and have not had any audio sync issues so far.
Keep in mind my Philips 985 is pretty old and does things a bit differently from the newer models like the 70, 75 and 80's.
Which VCR and DVD Recorders?
By Canes in forum DVD & Blu-ray RecordersReplies: 26Last Post: 11th May 2010, 20:48 -
DVD Recorders
By Dragoan in forum DVD & Blu-ray RecordersReplies: 4Last Post: 19th Mar 2010, 11:19 -
Stand alone recorders; more of a problem than PC recorders?
By videobruce in forum DVD & Blu-ray RecordersReplies: 24Last Post: 13th Nov 2009, 11:27 -
Basic editing: which Mac program for my DVD editing situation?
By Nuevonik in forum MacReplies: 4Last Post: 8th Jan 2009, 07:06 -
new U.S. JVC's DVD recorders
By StuR in forum DVD & Blu-ray RecordersReplies: 7Last Post: 1st Jun 2007, 10:58
